acc retrofit coding needed
hello all again
i have finished my retrofit on the ACC on my all road ,worked for three weeks but then i got the following errors :
any help and any idea how to code correctly ?all i need is the coding for the ACC the alignment is within limits...
regards
danikas
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H08 0080
Serial number: 00000000000000
Coding: 0079C0
Shop #: WSC 06777 128 28888
VCID: EFE650943ED12B66F2D-80BA
2 Faults Found:
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x0941
Hex Value: 0x0003
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x044B
Hex Value: 0x0002
Speed: -3.6 km/h
regards
danikas
Coding: 0079C0
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x0941
Hex Value: 0x0003
Speed: -3.6 km/h
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x044B
Hex Value: 0x0002
Speed: -3.6 km/h
you dont need to change the speedo just coding.
one interesting issue is that the steering stalk and controller come with lane assist button.all though i can code it to exclude this function
i found that once y accidental press the lane assist button on y turn indicator then there is an error code logged of incorrect coding because the system is picking up the lane assist function and then deactivates the ACC.Once y clear the fault with vag com the ACC comes operational again!
njcatchupaudi
NY / NJ / CT Discussion
08-14-2006 07:37 PM
DrGP
04-21-2005 04:37 PM
EkSiPd
09-25-2004 07:47 PM
undrway
12-30-2001 01:55 PM
MtDreamsTTQ
04-24-2001 04:28 AM
