A4 allroad (B8 Platform) Discussion Discussion forum for the B8 Audi A4 allroad, produced from 2012-present
acc retrofit coding needed
Old 08-20-2014, 07:25 AM
danikas's Avatar
Default acc retrofit coding needed
hello all again
i have finished my retrofit on the ACC on my all road ,worked for three weeks but then i got the following errors :
any help and any idea how to code correctly ?all i need is the coding for the ACC the alignment is within limits...
regards
danikas
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H08 0080
Serial number: 00000000000000
Coding: 0079C0
Shop #: WSC 06777 128 28888
VCID: EFE650943ED12B66F2D-80BA
2 Faults Found:
00234 - Sensor for Automatic Distance Regulation Misadjusted
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x0941
Hex Value: 0x0003
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 67137 km
Time Indication: 0
Date: 2014.08.19
Time: 17:40:22
Freeze Frame:
Temperature: 39.0°C
Voltage: 11.78 V
Bin. Bits: 01010
Hex Value: 0x044B
Hex Value: 0x0002
Speed: -3.6 km/h
Old 09-02-2014, 03:12 AM
danikas's Avatar
got the correct coding for anyone else need the info :
00C7D9 (WITH TRAILER)
00C7E0 (NO TRAILER)
Old 09-02-2014, 06:20 AM
Shaka's Avatar
Where did you buy the parts needed for the ACC retrofit? What parts were needed and how much did it cost? I'm very curious...
Old 09-19-2014, 11:08 AM
danikas's Avatar
Well the ACC got it from a german ebay dealer for 200 euros the stack for 139 euros and i made the wiring myself
you dont need to change the speedo just coding.
one interesting issue is that the steering stalk and controller come with lane assist button.all though i can code it to exclude this function
i found that once y accidental press the lane assist button on y turn indicator then there is an error code logged of incorrect coding because the system is picking up the lane assist function and then deactivates the ACC.Once y clear the fault with vag com the ACC comes operational again!
DrGP
04-21-2005 04:37 PM
EkSiPd
09-25-2004 07:47 PM
undrway
12-30-2001 01:55 PM
Quick Reply: acc retrofit coding needed
