Fog Lights?
#11
That said, the main beams, at least with the LED headlights, are quite wide and probably eliminate the need for dedicated fog lights.
#12
I would be grateful if you were able to share the DAP Grill Part #'s - really appreciate it. Also, I wouldn't be mad in the least if you checked for the Black Optics DAP Grill Part #'s at the same time. That would be perfecto! I wonder if the Allroad grills are different and if they even make Black Optics stuff for them.
#13
Those are 8W0807681Q (left) and 8W0807682Q (right). The only other available option for those are "satin black", add 9B9 to the end of the part numbers. FUQ I believe is the suffix for black optics but it doesn't exist in the parts catalog here, at least for the AR. You could try retrofitting the front end from the B9 sedan if you really wanted black optics stuff, the hardware behind the bumper cover looks the same between the sedan and AR.
There are no black optics parts for the allroad. Black window trim and roof rails/rocker panels are standard elsewhere but aren't glossy. Audi forces the silver appearance on US cars.
The front ends are swappable. I thought about un-allroading my car but then I couldn't run such large wheels.
#14
9B9 isn't an option. It's the only color the part is available in. Don't share things from the parts catalog (and a bootleg one at that) if you don't know how to read it.
#15
#16
In Europe, the Full Paint finish option automatically forces the Aluminium Look exterior.
#18
I love what you've done with your Got Green Allroad so far man - really looking great. You seem to obviously really know what you're doing as well. Thoughts on retro fitting some fogs like I'm talking about? Do-able? Crazy talk? curious what you think.
#19
Nothing is impossible. The adaptive cruise control radar modules mount to the bumper. The fog lights on the B8/8.5 did, too. It could be possible to adapt the radar sensor mounting plates (8W0907573 and 8W0907574) to hold a lamp instead.
You'll need a physical switch to operate the lights. On this platform, lighting is now digitally controlled by the vehicle bus. There are many spaces to stash it though, so that shouldn't be an issue.
An alternate approach would be to try and integrate some kind of LED lightbar (or two) behind the grille yet in front of the radiator. It might not be easy finding fog lights of a diameter suitable to fit inside the radar housing, leaving a gap. This solution lets you order a DAP car (if you wish) and still have the added benefit of extra lighting.
#20
Appreciate your thoughts on the topic!!!
