Cylinder #2 Misfire (PO302)
Old 07-09-2009, 06:00 PM
bronimar's Avatar
Default Cylinder #2 Misfire (PO302)
Hey guys i just found your forum and it looks full of useful information. I did some searching and did not quite get the results i was hoping for.
I have a 98 A4 1.8T. I got home from work the other day and when i pulled the car in the garage it started idling rough. The check engine light came on so i hooked up the code reader. It gave me a "PO302" cylinder #2 misfire. The car still starts up, but runs very rough. Not only at idle, but also when bringing the RPM's up. I looked over all the wires going into the coils and they look fine with no rips or exposed wires. I pulled the plugs and installed 4 new NGK's. Started the car and nothing. Throwing the same code.
I then pulled the coil packs off and swapped them ( I believe #1 with #2) Started it up and it was still throwing the #2 misfire (which should mean that the coil is good). I am not too sure where to go from here. I was not sure if maybe i should look for something else. I can try new Coil packs i guess, but the swap test sort of rulled out that they are ok. Any ideas please feel free to input i would really appreciate it. Have to drive the truck (8mpg) until the car gets fixed. Thanks, Marc
Old 07-09-2009, 07:11 PM
David.Norton's Avatar
Default Go for the power output module...
it is on top of the airbox, and the cylinder 2 failure is common.
Old 07-10-2009, 04:55 AM
bronimar's Avatar
Is this a part that i am going to have to pick up a a junk yard or that i can get new at an auto parts store? I really appreciate the input.
Old 07-10-2009, 05:24 AM
audi01a6's Avatar
yea,but do you know if its good or not,give me a part # see if i got one
i use to test cars or i can ck here at SUNCOAST AUDI for cost,ok
Old 07-10-2009, 05:32 AM
awdehere's Avatar
yeah just pick up the new ICM (ignition control module) and you'll be good to go.
Old 07-10-2009, 05:36 AM
awdehere's Avatar
heres a good deal on one
http://www.audizine.com/classifieds/...=17347&cat=all
Old 07-10-2009, 10:21 AM
bronimar's Avatar
I am going to test it tonight when i get home from work to double check. I was looking through some old posts and "ArandA4" put up a great DIY test procedure i am going to give a try.
It looks as if the one for sale for $75 has a sale pending already. I wish i would have seen it a little sooner, but oh well. If it tests out bad (which i really hope) i will post up a part number. Any idea on what cost price is audi01A6?
Thanks for all the help, Marc
Old 07-10-2009, 12:05 PM
Edwardo's Avatar
I just went through this issue a month ago. It was the ICM like people are saying even though I did the DIY test and didn't get conclusive results. I think mine was only partially failing because it was relatively intermittent. Get the Huco replacement part instead of the Bosch. I got mine from http://getcoolparts.com/, but quite a few places have it for under $100 new.
Pathart500
09-08-2014 07:43 PM
devinsixtyseven
10-05-2013 07:53 AM
A4Schnell
04-26-2008 04:47 AM
SteveAngry
10
09-28-2007 06:45 PM
fourwheelslide
03-13-2006 04:43 AM
Quick Reply: Cylinder #2 Misfire (PO302)
