2000 a4 ac problems help
I just purchased a 2000 a4 I have no ac compressor clutch does not activate I searched here but can not find where the ac low psi switch is and which pins to jump or supply +12 v to. Any help appreciated.
The first thing I would do is see if you are getting a signal to the single wire on the compressor clutch, when the ac is turned on. If you are and you say the ac isn't working, then the compressor has failed and you won't need to go any further.
PakDaddy
01-10-2000 05:57 AM
