New Rear End Grinding when Cornering Hard (not wheel bearings)
Old 02-20-2015, 11:23 AM
ams
ams's Avatar
Default New Rear End Grinding when Cornering Hard (not wheel bearings)
I have a 2001 A4 Quattro with 190k miles (getting up there, I know). The last few months I've observed a very loud/pronounced grinding noise on hard long radius right-hand turns coming presumably from the rear drivers side of the car.
I had drivers side rear wheel bearing replaced and no difference. I also changed the rear diff fluid and no difference.
A few observations:
- it only happens when the car is fairly 'loded up' in a turn. In one of these long turns if it is easy, no noise, if I jerk the wheel a little tighter it comes full on.
- it 'appears' to only happen under power/accel. I was coming down a windy mountain pass and when I put it in neutral or clutch in I can take sharp fast corners as hard as I can and everything is super quiet. But if i try and accelerate through similar corners it happens.
I've done a lot of searching and for similar symptoms the diagnosis is usually wheel bearings or rear break pads/calipers rubbing, but this doesn't appear to be my case.
Thinking maybe rear diff?? I've never really read a thread where someone's rear diff actually went bad or had to be replaced (other than leaky seals).
Thanks!
gag4o
04-03-2016 02:42 AM
quattrospg
02-23-2009 08:25 AM
BiturboBoy_V2.0_S3--
07-09-2004 02:34 PM
Silver90Quattro
09-26-2003 04:50 AM
shadyraven
05-27-2002 07:01 AM
Quick Reply: New Rear End Grinding when Cornering Hard (not wheel bearings)
