Crudola.. Discovered that the upper transmission line into the radiator is leaking slightly...
Old 08-31-2008, 03:52 PM
Head Cat Herder
Kris Hansen's Avatar
Default Crudola.. Discovered that the upper transmission line into the radiator is leaking slightly...
not sure about the lower one.. I was worried about these when I changed the radiator, I re-used the O-rings, which in retrospect, I suppose I should not have.. Luckily, it's easy to get at them without too much effort..
Question I have for myself and others.. anyone else installed a new rad, and not have problems with the automatic trans lines? it was a bitch getting them in, they're really tight..
Old 08-31-2008, 04:49 PM
Allroady DungBeetle's Avatar
Default You need lube before putting it in there - it's really tight.
Wow that sounded bad huh??!! ;-P
The TRANSMISSION LINES need a little good lube on the o-rings so they can slide in there, if you go dry it will go hard and she'll often have seepage after since it can score the o-rings.
Old 08-31-2008, 05:22 PM
Tech Guru
4Driver4's Avatar
Default Our old 1993 had a chronic leak there. I probably replaced those o-rings 5 times.
It would be good for a few months, then start leaking again. Eventually I got tired of it and installed a separate cooler.
Old 08-31-2008, 06:26 PM
@wesome's Avatar
*unzips pants*... tell me more about what you want to lube and put in
Old 09-01-2008, 03:42 AM
Head Cat Herder
That's what I'm afraid of, and I had the same thought as a solution....
Old 09-01-2008, 03:43 AM
Head Cat Herder
Default I used a little Vaseline...
I have not looked at it yet, I wonder if the bolt loosened up.. *wishful thinking.. *
Old 09-01-2008, 05:50 AM
Head Cat Herder
Default Upon further inspection, the top O-ring is damaged, not sure about the bottom..
I have not pulled it out yet, knowing that I need at least the upper, I'll go pick up a few of them, and then replace the lower regardless...
Old 09-01-2008, 06:46 AM
Tech Guru
4Driver4's Avatar
Default OEM is teh best.
In all seriousness, buy the new o-rings from Audi. They are much harder than standard o-rings.
Old 09-01-2008, 07:09 AM
Head Cat Herder
Default So what do you suggest till I can get them? Put it back together with the damaged ones?
I noticed that these o-rings do seem really firm, and was wondering about the chances of getting similar ones.. Most O-rings tend to be really soft..
Old 09-01-2008, 07:10 AM
I was lost, now I'm found
myers1.8TQ's Avatar
Default Yah when I replaced my radiator, . . .
It seemed like it had to be in the exact position and took forever to get them just fitting correctly. Then after that it was just as hard to keep it in-line and bolt them in. It was probably the hardest thing out of the whole job of replacing my radiator, fan, tran. fluid and everything else you have to do.
Quick Reply: Crudola.. Discovered that the upper transmission line into the radiator is leaking slightly...
