CV boot replaced, but still noisy
Old 07-24-2014, 09:09 PM
c2sawyer's Avatar
Default CV boot replaced, but still noisy
Any advice? I replaced a torn driverside cv boot that was clicking pretty good on right turns. The races and bearings were in great shape but there was some small pitts on the cage. Still getting the same loud clicking on right turns.
I'd rather not replace perfectly good races with a new joint because the cage is bad, any suggestions?
Old 07-25-2014, 06:48 AM
turbo510's Avatar
I don't see how a cage with small pits can cause bad clicking. The clicking comes from lack of grease, without which the ***** will scoot along their groves until hitting the cage. Other than limiting how far the ***** can move, the cage doesn't do much else.
Old 07-25-2014, 11:32 AM
Prospeeder's Avatar
If it was clicking its junk, the only way you can get a way with rebooting an axle is if it was still quiet and has no play or wear. Buy a new axle assembly. I have good luck with OP Parts axles and FEQ, they can be had for 50-80$ each. Dont bother trying to fix the outer joint. The inner joints wear out and fail and make vibrations eventually. No point in limping along a 50-80$ part....
Old 07-25-2014, 06:26 PM
c2sawyer's Avatar
good to hear someone has had good luck with FEQ, I've heard nothing but horror stories so far with remfg axles.
LPS74
Audi allroad
10
12-13-2009 11:40 AM
Number54
20
11-14-2008 10:10 AM
TurboA6
08-09-2008 08:35 PM
I'm No Pro
06-15-2006 02:46 PM
lukin36
12
12-05-2002 05:34 PM
Quick Reply: CV boot replaced, but still noisy
