A very clean b5 at the dealership, advice needed.
Old 02-15-2011, 09:53 PM
arU4ic's Avatar
Default A very clean b5 at the dealership, advice needed.
Howdy! My first post here, I'm on the q7 mostly these days.
I saw a pretty cherry 2.8 quattro B5 at the dealer for 10k. Leather, sunroof. 77k miles. 1 owner.
I am pretty much a DIY guy, I have vagcom and lots of tools (for a q7 owner)
What are some things I should look at immediately. I usually go right for oil in, around, under the engine, check clutch play and cv boots, rotors and pads, anything a4, B5 specific I should really look at?
Thanks.
Old 02-16-2011, 02:57 AM
Tech Guru
4Driver4's Avatar
Check to see what year it is and what transmission is in it.
Old 02-16-2011, 05:10 AM
jaredwilson's Avatar
You're on the right track checking for oil leaks. My car has developed quite a few oil leaks over the years.
The control arms go bad pretty frequently. Listen for clunks or squeaks when driving slowly over bumps and, if you can, jack up the car and check the back-and-forth play in the wheels. There shouldn't be much if any movement, so if there is, the control arms are likely on their way out. The coolant temperature sensors go out as well. These are easy to check since they send the signal to the temperature display on the center console.
Good luck.
AudiMick's Avatar
Thanks.
It's probably due for a timing belt. Check the suspension for control arm clunks etc.
Old 02-16-2011, 06:11 AM
Tech Guru
4Driver4's Avatar
Did you mean to respond to me or the OP? I did not mention any leaks.
Old 02-16-2011, 06:29 AM
The OP mentioned checking for oil around the engine. Sorry for any confusion.
Old 02-16-2011, 06:47 AM
Tech Guru
4Driver4's Avatar
No worries. I figured you wanted to respond to him but responded to my post by accident.
Old 02-16-2011, 07:22 AM
joloya's Avatar
For 10K ?? It's too much. That car is probably 10+ years old and it's due for bearings, shocks, control arms, timing belt etc.. Since, you know your stuff, I would look for something around 1500-2k then, spend arount 1k for necessary parts.
Thanks.
Old 02-16-2011, 07:28 AM
arU4ic's Avatar
Ooops left out the year:
2001
Old 02-16-2011, 02:35 PM
5v/cyl's Avatar
2001
10K is too much for a 10 year old A4 no matter how nice it looks. Too many age related issues that could be a problem. 9K would be max to pay, but that would have to be like new condition with ALL service records and 100% up to date on everything.
Quick Reply: A very clean b5 at the dealership, advice needed.
