Fans
Old 11-23-2014, 01:53 PM
Ryan'sAudiA4's Avatar
Default Fans
What would be the cause of my cooling fan coming on as soon as I start my car, even from a dead cold?
Old 11-24-2014, 03:02 AM
twentysevenlitres's Avatar
Air conditioning via the climate control.
Press 'Econ', or turn the unit off (fan manually reduced to zero usually does it), and see if it still does it.
Old 11-24-2014, 04:27 PM
I meant the radiator fan lol my bad :P
Old 11-25-2014, 07:11 AM
clancy's Avatar
The electric cooling fan on the radiator is turned on when the cabin heating/cooling system is set to auto. That is what twentysevenlitres was saying. The air conditioning compressor is on whenever the climate system is on and not set to econ. This also turns the electric cooling fan on. Turn off the climate system or set to econ and see if the electric cooling fan turns off.
Old 11-25-2014, 10:42 AM
frazgsi's Avatar
Thank god someone else is having this issue. ive just bought a 1999 a4 2.8 and the radiator fan is always on (the main one and not the electric one), even from cold. Driving me insane because the car sounds like a bus.
Old 11-25-2014, 04:21 PM
Its still on after I turn off the climate system.
Old 11-27-2014, 05:53 AM
David.Norton's Avatar
The engine driven fan should always turn, however there is a clutch on it that tightens up as the engine gets warm. With the car cold and the engine off you should be able to turn the fan by hand, if you cannot you have a bad fan clutch.
GTHMH
05-23-2010 05:22 PM
CalgaryS4
05-02-2006 07:12 PM
dahktahjay
08-18-2003 04:11 AM
djtalon
11-16-2001 11:29 AM
Jon
10-26-1999 03:33 PM
Quick Reply: Fans
