Front outer CV boot torn. What's my options?
The front outer cv boot on passenger sider of my A4 quattro got torn recently. (About a month, probably less than 1000miles before)
They quote about $330 for boots job and after going through some articles it looks like nice weekend DIY Job:
AudiWorld Tech Articles
I am new to fixing anything in the car but comfortable using tools. Is this something to do for a novice?
I can use a DIY shop where I can use for reasonable hourly charge with lift and tools if it makes sense. Or I can just use jack to hold it up and work on the drive way.
So there seems to be a few options:
1. Replace the CV boot soon and save the good original cv joint.
2. Just leave it until the cv joint goes bad and starts make noise. Than replace the cv joint and boots.
or
3 replace the whole axle to avoid dealing with grease
In case, I replace the boots only, can any one confirm the right part number? Or good brand/store to buy? It is for 2000 A4 Quattro 2.8L Manual transmission.
I cannot figure out what is the difference between these two:
4A0-498-203A
4A0-498-203C
Also there seems to be a few different approach to free the outer cv joint from the wheel.
1. Unscrew the inner cv joint and detach the whole axle.
2. unscrew the tie rode end and remove the outer cv joint only
3. unscrew the upper control arms and remove the outer cv joint only
Some people suggest #1 as pinch bolt for tie rode or control arm are often frozen and hard to work with.
I am missing anything?
Thanks,
or
4A0-498-203A
4A0-498-203C
Thanks,
Thanks Kris for the quick reply.
Any significant difference in terms of time and effort between removing the whole axle vs. just outer cv joint?
And should I be concerned about the quality of the none OEM like rein or GKN? Especially the axle bolt included in the kit?
Thanks again,
Thanks again,
Nish
S6 (C7 Platform) Discussion
09-14-2015 10:02 AM
S4intheOC
09-08-2015 12:12 AM
