how to remove panel around hazard flasher switch
Hi all,
I am having problem with my hazard flasher switch (doesnt blink after 1 or 2 blinks), from my research, i believe the problem source is bad hazard flasher sw.
I got the parts, but, i dont know how to remove the panel around it (preferrably not to break it). Is there an instruction on how to remove the panel? or can someone pls be so kind to help me. Thanks in advance.
-jjc.
-jjc.
My experience with my car (2001) is that there's no way to get it out without breaking it...
I broke the tabs off and glued them back on when I got done with it, but as most people on here will tell you: The B5 FAQ and the search functions are your friends.
real easy. use a small flathead screwdriver and start from the bottom right next to the middle.
do both bottom sides and then the sides and then the top. hell here are some instructions.
Alen<ul><li><a href="https://forums.audiworld.com/southeast/msgs/12987.phtml">https://forums.audiworld.com/southeast/msgs/12987.phtml</a</li></ul>
Mine is 98.5, the panel covers the entire weather controll unit.
Thanks all for speedy replies.
Now, mine is 98.5, the panel covers the entire front (from hazard sw to weather control unit)..
would the same method still apply? please be so kind to confirm..
Thanks!
-j.
Thanks!
-j.
is there an instruction on how to pull the radio,?
once again,
thanks for speedy reply. It "seems" fairly troublesome...
is there any instruction on how to remove the radio? thanks!
what would be the labor be to do this (I'm in Bay area (nor cal))
-j.
-j.
Lutri
Audi 100 / A6 (C4 Platform)
06-18-2012 06:52 AM
JMBlur
04-01-2008 02:05 PM
MuRaN0Daddy
Audi A3 / S3 / RS 3
04-27-2006 03:42 PM
