Removing clutch fan without special tool...
Old 02-12-2009, 09:25 AM
  #21
I was lost, now I'm found
myers1.8TQ's Avatar
Default Here is what I found out. AEB 1.8T, not reverse thread. JMBlur answer:
on the 1.8T, you can take the whole assembly off (fan/clutch/pulley) but to get it out of the car you will have to find a way to remove either the fan from the clutch, or the clutch from the pulley. That is on the 1.8T, now for the 2.8L I am not sure what it takes.
Old 02-12-2009, 09:38 AM
  #22
JMBlur's Avatar
Default Thanks! Will have to take a look myself, haven't had a chance yet to investigate
always sucks when something else breaks before you even get to drive the car after the last fix!
Old 02-12-2009, 09:41 AM
  #23
myers1.8TQ's Avatar
Default No problem. You had the drive shaft issue correct?
I know what you mean but it is a good thing to wait before driving with a bad fan clutch. I ended up replacing 2 fans, dents in my hood and replacing 1 radiator (I got really lucky the second didnt get destroyed).
Old 02-12-2009, 10:13 AM
  #24
ZB4rngs's Avatar
Default Dude? Did you like, break off all your fan blades?
That would be one way to "make a little room"
Old 02-12-2009, 10:19 AM
  #25
myers1.8TQ's Avatar
Default Nope, fan clutch was seized and the plastic fan couldnt handle high RPM's and blew apart.
That was a new one as well.
Old 02-12-2009, 11:27 AM
  #26
@wesome's Avatar
Default ...
<img src="http://i48.photobucket.com/albums/f230/imawesomea4/Motor%20build%20up/IMG_4558.jpg">
Old 02-12-2009, 11:47 AM
  #27
aluminumpork's Avatar
Sorry, I should of stated, I have a 30V, no easy way to get behind the pulley like that.
Old 02-12-2009, 12:02 PM
  #28
Joey T
Guest
Posts: n/a
Default Where are you?
I use an air hammer with a long chisel, as does almost every flat rate tech in thge world
the green amigo (11-08-2021)
Old 02-12-2009, 12:14 PM
  #29
JMBlur's Avatar
Default Yeah, that's me. Was yours slipping to start, or did it seize completely?
Mine appears to be working but slipping... guess I should probably fix it sooner rather than later though!
Old 02-12-2009, 12:17 PM
  #30
ZB4rngs's Avatar
jeeez
Quick Reply: Removing clutch fan without special tool...
