Installed boost gauge - still surging around 2000 rmp - here are the readings
Old 07-22-2004, 06:01 PM
New Member
burbage's Avatar
Default Installed boost gauge - still surging around 2000 rmp - here are the readings
here are the readings - 20 in vac, 15 psi spike, 10-11 holding. It stops around 2000rpm, then goes up then stops then goes up. I changed the bpv, checked teh vac lines. Think its the n75?
Old 07-22-2004, 08:46 PM
Forcefeed18T's Avatar
Default Im getting surging too...
For me its at low rpm as I apply throttle to accelerate usually going uphill, I hit a "not so sweet spot" on the pedal. My boost fluctuates between 5-8psi up down up down up down...dammit until I either let off or push down on the pedal... Trying to work it out with my mech as he has since sent my chip back to AMS to reburn...I think the chip is the culprit as everything under the hood is new. See what happens....
Python021
1.8T Discussion
08-20-2009 08:50 PM
Nate (ETKA+Scumbag)
03-09-2006 04:26 PM
slimcubby
06-26-2005 08:57 PM
Morio
27
02-23-2005 09:21 AM
djillusion
08-18-2002 06:48 PM
Quick Reply: Installed boost gauge - still surging around 2000 rmp - here are the readings
