2003 A4 Cabriolet Mass Airflow Sensor Transmission Limp
Old 03-29-2015, 06:33 PM
drfdifj22929's Avatar
Default 2003 A4 Cabriolet Mass Airflow Sensor Transmission Limp
I think my 2003 A4 is in what I've seen people call "transmission limp". When I first start it it stays in first gear on the display and I can't change it, but after putting it in Park then Drive again all the display says "PNDR" all lit up at once.
I have 2 OBD II codes for the system being too lean (both banks), so could the MAF be causing the limp? And would cleaning it help? If so, how feasible is it and would something like this work (
404 - Document Not Found 404 - Document Not Found
Old 03-30-2015, 07:19 AM
lyleswk's Avatar
What code tool did you use? If a generic, it won't read transmission codes. The MAF won't cause the transmission to go into limp. There is another issue as indicated by the PRNDL lighting up. You need a VAGCOM reader that will read VW / Audi specific codes.
Ivan Corona
11-28-2018 11:55 PM
Matt Devo
10
06-23-2006 10:53 AM
mable
07-17-2004 01:45 PM
MelloYelloS4:Indkted
14
04-21-2004 08:45 AM
skl1
11-22-2003 02:15 PM
Quick Reply: 2003 A4 Cabriolet Mass Airflow Sensor Transmission Limp
