2003 Audi A4 headlight problem
My girlfriend has 2003 Audi A4 1.8T with Xenon headlights.
Drivers side xenon stopped working. I changes the bulb from passengers side to drivers side and its not working again.
SO i put drivers side xenon bulb into passengers side and it works fine.
What can be the problem?
Additional info:
It has DS1 bulb inside.
Its mono xenon light.
Everything else: like long lights and turn signal works fine.
I Also noticed that reflector on the drivers side headlight is silver and on the passengers side is black/gray plastic.
My guess is that the car was in small accident or something and they changed one headlight. Thats why they are different.
Despite all those differences the headlights were working fine before.
Thank You.
Additional info:
Thank You.
Pull housing from car, ballast is on bottom , unclip power harness, unclip bulb wire...
there are 6 torx screws that hold it in housing.
if you swap ballasts with other side and it doesn't work, you know its ballast.
also, you can get ballasts on ebay for 90 USD.
you can use a 5G ballast or a 5GL ballast for 2003 A4.
Cmmartin23
26
08-23-2016 04:44 PM
PaulNZallroad
Audi allroad
09-17-2015 04:46 AM
