2004 Audi A4 leaking oil
Old 10-04-2016, 01:55 PM
huntings's Avatar
Default 2004 Audi A4 leaking oil
I cannot find the leak for the life of me but it keeps leaking oil, not a whole lot but enough to leave an oil mark wherever i park, i recently had an oil change and the tech did not find an oil leak anywhere.
Old 10-05-2016, 05:26 AM
lyleswk's Avatar
Not sure how to help with the few details you have provided. Oil leaks can come from numerous places and depending on where you got the oil change, the tecdh may not be competent enough to figure it out.
Old 10-05-2016, 08:15 AM
W261w261's Avatar
Put the car on ramps and clean under the engine using engine cleaner from Autozone. Use a brush if necessary. Rinse and let dry. Drive car off ramps, start and let idle for 10 minutes. Look for drips. Drive car up on ramps. Take a flashlight and crawl under and search.
Old 10-05-2016, 08:26 AM
huntings's Avatar
Sounds like plan. Thank you for the Help.
Old 10-06-2016, 05:36 AM
W261w261's Avatar
Also, be sure to use safety goggles, the kind that completely enclose your eyes. The engine cleaner stings.
Old 10-09-2016, 05:57 PM
dvfosho6's Avatar
Mine was leaking and I replaced valve cover gaskets and it stopped. There is a write up somewhere to do it yourself, pretty easy actually.
Old 10-10-2016, 11:21 AM
W261w261's Avatar
Take a look at the spark plugs. If there's oil in the depressions, there's a leaking valve cover gasket.
Old 10-14-2016, 07:55 PM
steveracer's Avatar
Do you find a general amount of oil on the back of the engine, dousing the transmission and front subframe? How many miles?
Another possible source (from experience) are all of the crankcase breather hoses on the driver side of the engine, under the intake and rearward of the oil filter. They disintegrate, drip oil, and if you can smell oil, this may be a good place to look - or feel as it may need to be.
Old 10-16-2016, 08:08 AM
rocket1420's Avatar
Could also be the front axle seals, or the propshaft seal. The rear main can also leak, especially if your pcv valve is bad.
Old 09-06-2017, 04:19 AM
Pushbutton_auto's Avatar
Yeah, clean the engine then the source should be easy to locate.
jiggysmb
Q5/SQ5 MKI (8R) Discussion
9
11-20-2017 05:49 AM
actac95
11-25-2008 11:07 PM
sk88erguy
10
04-23-2004 04:01 PM
imo46
Audi 100 / A6 (C4 Platform)
02-12-2004 08:09 PM
The Turtle
04-23-2003 10:17 AM
Quick Reply: 2004 Audi A4 leaking oil
