A4 headlights halogen or xenon?
I need to replace my headlight housing. From my research the xenon and halogen assemblies look pretty much the same on the outside. My bulbs are xenon but I am not sure which housing to buy? Any help is appreciated.
Audi lists two part numbers for the housings, but I think they include the bulbs, which could account for the difference in cost. I own 2 B6's, one of each type, and I have changed the bulbs in each and they appeared identical, although I wasn't specifically looking for differences. Maybe the dispersal pattern is different.
Audi list on these guys is $717, discounted is $500+. Try Tom's imported auto parts in CT for out of a wreck. They could probably tell you if the housings are different.
OK when I look up bulb types for the my headlight it tells h7 halogen and d1s for xenon. I pulled out the bulbs on mine and it says d2s. So I looked up the different bulbs and d1s will definately not fit. And as for the h7 the connectors are different than from the d2s but does fit in the socket. What is going on here?
No idea. You have me totally confused. H7 is halogen and D2s is xenon. They are not interchangeable.
But the bottom line is if you buy a new headlight assembly make sure the part# is the same as the one you are replacing. Then you will have no issues.
ex-quattro PETE
06-24-2003 11:17 AM
AEGA4
03-12-2003 01:01 PM
