:: ECS Tuning :: NEW!! Stahlbus Oil Drain Valve Set | B6 A4 1.8T
Audiworld Basic Sponsor
A conventional oil change is always associated with spills and dirty hands. Therefore, this system has been developed with which you can perform an oil change completely safe and clean.
The stahlbus oil drain valve will easily replace the existing drain screw. When changing the oil, you unscrew the cap and put on the hose connector via quick release. Only when this is locked, the valve opens and the oil can be drained into the provided container.
When disconnecting the hose connector, the valve closes automatically and you only have to turn on the cap.
The Modern Oil Change
Click HERE to order or for more information
Fits:
Audi B6 A4 1.8T 2002-2005
Be sure to check out our -----> Oil Change Fundamentals
Let me know if you have any questions.
Jason
ECS Tuning-Audi
07-15-2016 01:17 PM
Tom (90Carat)
Audi Original "S" Cars
9
08-27-2008 05:57 PM
do I have to clean PCV valve if its clogged by oil? or is it something wrong if oil is in PCV valve?
S4AVT
03-28-2006 12:24 PM
