No start after head gasket job
First off id like to say hi to everyone since this is my first post. Now let me jump into it. I bought this 2003 Audi A4 1.8t quad off a buddys buddy who had overheated the car due to thermostat neglection. I knew there was a sh*t ton of work to do but i got the car for a steal of a price. So after replacing the head gasket, thermostat, water pump, temp guage, coolant flange, cam chain tensioner, timing belt tensioner, injectors, spark plugs, gaskets, new vacuum lines where needed and a new battery the car still wont start. Spark plugs are wet with fuel after turning it over and compression is good in the 4 cylinders. Timing on the crank and cam pullys line up correctly with the marks. No codes on the dash. So now im stuck here. After doing a bit of research, it seems i might need to buy a vag con scanner and set the basic settings or something along those lines. Are there any suggestions or advice to help me check if its something else before go ahead and cash out on the software. Any help is appreciated and thanks in advance!
I am pretty sure you need to do the throttle body adaptation.
I did a very similar process on a 2.0L FSI engine and the damn thing just would not start. In desperation I purchased the Ross Tech Vag-Com, ran the adaptation and the engine fired immediately.
My understanding is after a battery disconnection, the ECU should run the adaptation automatically if you just turn the ignition to ON (not start). You should here the 'whir' as the throttle body runs full open, full close etc, takes about 60 seconds. Turn ignition to off and then start as normal.
I don't know why mine would not do it automatically. Maybe having the battery disconnected for an extended time or maybe I had stuffed up the throttle body position too much when I was cleaning it but it would not do it automatically.
I had to disconnect the battery again recently for about 20 minutes to do an air bag plug removal, the automatic adaptation worked perfectly on reconnecting the battery.
I have found the VAG-COM to be useful since so it is not wasted money.
Ended up buying the wire and vcds software and following the throttle body alinement instructions. Still no luck. Motor turns over but it wont spark. Im thinking ive flooded it so im waiting for it to dry out now. these are the codes i pulled out of the vag software. "Signal for Duration of Ignition Off Time" and "Supply Voltage B+" are the two codes that i feel i should start with. If anyone has any experience with these codes please do chime in
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0001
Coding: 0016751
Shop #: WSC 63351 000 00000
VCID: 74E1AC9214CC45BE8F5-5072
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 P
Component: AG5 01V 1.8l5VT USA 0910
Coding: 0001002
VCID: 3B7347AE7912CAC68EF-5072
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
VCID: 2D5779F6E766547600B-5072
1 Fault Found:
01486 - System Function Test Activated
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 2A5D72EAD688434EE59-5000
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
VCID: 34616C92044C05BE4F5-49D8
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
VCID: 377B5B9E453AEEA66A7-5000
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
011 - Open Circuit - Intermittent
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
VCID: 3C7144B22C1CCDFE875-49D8
1 Fault Found:
53-10 - Supply Voltage Too Low - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 26149
VCID: 326D6A8AFE580B8E5D9-5072
WAULC68E03A122117 AUZ6Z0B0176980
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBD337EE99F21A46DEF-50E6
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 72EDAA8A3ED84B8E9D9-4A3A
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0002
11 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
08-10 - Control Limit Surpassed - Intermittent
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
00957 - Key 3
35-00 - -
01561 - Rear Left Door
59-10 - Can't Unlock - Intermittent
00934 - Electric Window Motor; Rear Left (V26)
62-10 - No or Incorrect Adjustment - Intermittent
01803 - Door Warning Lamp; Rear Left (W37)
57-10 - Electric Circuit Failure - Intermittent
End ---------------------------------------------------------------------
Coding: 0016751
Coding: 0001002
Coding: 04277
Shop #: WSC 06435
1 Fault Found:
35-00 - -
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 00003
Shop #: WSC 63351
Coding: 0010607
3 Faults Found:
Coding: 00041
Shop #: WSC 63351
1 Fault Found:
Coding: 03200
Shop #: WSC 26149
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 11788
Shop #: WSC 63351
11 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00957 - Key 3
35-00 - -
Never had anything like this, but based on those codes (which seem odd that one is under HVAC and one is under the airbag), you have left something disconnected or broke some wiring while doing the head. See below for general troubleshooting from the Ross-Tech site for those codes. I would start with the ground
01206 - Ross-Tech Wiki
00532 - Ross-Tech Wiki
laet_00
09-02-2014 04:26 AM
coupegt83
06-10-2012 07:09 PM
cgt83
02-18-2009 11:54 AM
Joey T
01-23-2008 06:55 PM
