Motor Mounts
Old 09-11-2008, 08:07 AM
New Member
tmcatee's Avatar
Default Motor Mounts
So I am starting to leak fluid from the motor mounts, so as I am about to replace the mounts I wanted to see if anyone had any opinions on which mounts to go with? Are the OEM mounts just as good to go with for replacements? I didn't plan on doing much for engine mods so trying to get by as cheap and practical as possible.
Thanks in advance!
2002 1.8t - FWD
Old 09-11-2008, 08:29 AM
The Beave's Avatar
Default 034 Motorsports
I have the street density and they have worked great.<ul><li><a href="http://www.034motorsport.com/product_info.php?products_id=772">cleekkk...</a></li></ul>
Old 09-11-2008, 09:49 AM
New Member
tmcatee's Avatar
Default Re: Thanks!
Yeah I was just on your website yesterday looking at these, very nice!
Old 09-11-2008, 10:28 AM
The Beave's Avatar
Default no worries
I would suggest getting the transmission mounts they have as well, really helped me clean up the driveline slop that i was starting to get over time. nice part is these are solid rubber so there will never be an issue with them leaking.
Old 09-11-2008, 10:50 AM
JayP's Avatar
I got the street- wish I'd gone with the track. Streets are a good alt to stock.
Old 09-11-2008, 11:19 AM
New Member
tmcatee's Avatar
Default Good deal!
Yeah I def need to replace the transmission mount at the same time, lots of slack. Had to check the other day just to make sure nothing actually broke into two pieces. So there is a pretty big difference between the street and track versions?
Old 09-11-2008, 11:38 AM
The Beave's Avatar
Default haven't felt the track ones
but the street density are a little stiffer than the stock. I've heard some people that didn't like the track density because they could feel more of the engine vibration. I think it just comes down to a matter of what you're looking for. Do the tranny and motor mounts for sure, then go for a snub mount to really clean it up. After I did that my driveline felt as tight as a new car.
Old 09-11-2008, 12:30 PM
ScratchRob13's Avatar
track density are extremely stiff.. vibrating inside the car stiff...
Old 09-11-2008, 02:10 PM
Junior Member
Denim'03's Avatar
Default Stick with the street....
Unless you are running insane horsepower. And yes, the street mounts will vibrate/hum at about 3.5k rpm, highway speed for the 5-speed.
Old 09-11-2008, 02:18 PM
Junior Member
Denim'03's Avatar
Default Here's a trans mount for ya...
<ul><li><a href="http://www.audizine.com/classifieds/showproduct.php?product=2104&amp;cat=21">~~~~Click ~~~~~</a></li></ul>
Quick Reply: Motor Mounts
