Possible to disable seatbelt chime?
Old 12-02-2011, 01:36 PM
abcxyzzz's Avatar
Default Possible to disable seatbelt chime?
Hi,
Does anyone know a way to disable the seatbelt chime? Sometimes when I'm just sitting in the car with the radio on, the seatbelt chime keeps ringing every 30 seconds. It's quite annoying. So is there a way ti disable it? Thanks.
Old 12-02-2011, 07:03 PM
A4Audi4Fun's Avatar
Originally Posted by abcxyzzz
Hi,
http://vagtoolfinder.com/locator.aspx - use this link to find someone in your local geography with the VCDS tool from Ross-Tech. They can then access the configuration options for your car and deal with the seatbelt chime.
Old 12-03-2011, 02:35 AM
JohnBoyToo's Avatar
Yes, it can be disabled, but curious - do u have the ignition ON or just in accessory mode ?
many times I will turn the car off and sit there while the wife is shopping and the radio will play without anything on for 10 minutes or so...
but if longer, will push the key without starting and turn it back off, then our Q doesn't chime when in accessory mode...
Old 12-05-2011, 08:22 AM
abcxyzzz's Avatar
Hi,
I just have it in accessory mode, so that all the interior lights and radio light up, but didn't turn it to start the car.
I'm not sure what you mean you will "push the key without starting and then turn it back off?" What if I want to just sit there and keep listening to the radio without having to put on the seat belt?
Note: I'm referring to the car not having been turned on or off yet. Just getting into the car like during my lunch break and listening to the radio w/out having to turn on/off the car. Thanks
Old 12-05-2011, 09:30 AM
lyleswk's Avatar
What he is saying is the key does not have to be in the ignition at all. Simply sit in the car, leave the key in your pocket, and push the radio button. The radio will come on.
Old 12-05-2011, 12:04 PM
A4Audi4Fun's Avatar
And the radio will turn off automatically after approx 60 mins, if left in that mode. Audi seemed to be pretty good about making sure the radio wouldn't drain the battery.
I've only ever heard the set belt chimes after I have turned the ignition key to the ON position.
Vladko1969
6
01-02-2018 05:14 AM
microfilter
Q7 MK 1 Discussion
04-03-2010 03:24 AM
Yea Snow
Q7 MK 1 Discussion
11
11-06-2006 07:26 AM
My 4 Rings
13
10-14-2002 07:16 PM
Brent V
06-15-2002 04:13 PM
Quick Reply: Possible to disable seatbelt chime?
