Fault after Scan
Fault after Scan
Hi i am getting the following Error after VCDS Scans
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004526
Shop #: WSC 06335 000 00000
VCID: 2959E1ED80920956EC3-807C
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 19
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x0001
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 0
Date: 2014.06.17
Time: 12:37:49
Does nau one know what it is . my dealer wants 1500 To replace the steering control module saying there is no communications . Is that a correct fix for this ?
any advice would be good.
Thanks
Coding: 0004526
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 19
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 0
Date: 2014.06.17
Time: 12:37:49
Thanks
Coding: 0004526
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 19
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 0
Date: 2014.06.17
Time: 12:37:49
Thanks
Coding: 0004526
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 19
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0196
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Time Indication: 0
Date: 2014.06.17
Time: 12:37:49
Thanks
I've received G85 false reading plenty of times after disconnecting the battery, this happens most of the time.
The frequency of 00466 makes me curious. Are the accessory buttons on your wheel working at all? If not it would be the logical deduction to replace it, Audi usually won't try to recode anything and they're usually correct on module replacement.
What were the accompanying symptoms - the reason you went to the dealer?
bballfreak
9
04-14-2019 06:59 PM
ECS Tuning-Audi
RS4 (B7 Platform) Discussion
08-14-2017 08:39 AM
ECS Tuning-Audi
09-28-2015 12:18 PM
