A4 S Line 2010 CCM location and window fuse
Hello all, a bit new to thse forums so hope I can provide all the required information for a quick question.
After some issues with all my windows randomly going down I tried to find the fuses to isolate them while I resolve the issue with a suspect CCM.
The passenger windows fuse (30A) is in the drivers fuse bay, but the detail referencing the main drivers side has no fuse in the slot so suspect its from another main control fuse.
Where can I find the fuse for the drivers side electric window. Any advice please ?
And is the CCM under the drivers seat well on a 2010 A4 S-line or has it moved ?
I expect it is wet as I've checked for fault codes, the auto window close option is disabled in the MMI and checks prove holding down the buttons on the fob wont close/open windows which is correct.
Appreciate any help while I sort this fault out.
UPDATE: In case anyone is searching, the drivers side windows are fused from the boot (trunk) in the brown bank of fuses #6 behind the first Aid netting / 12v socket panel on the right.
Hopefully someone can confirm if the CCM is under the floor well on the drivers side ?
Rally_nutcase_1982
08-12-2007 07:55 AM
