A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Adding real dipstick to 2010 A4 2.0T engine
Old 09-11-2010, 02:54 PM
bondi's Avatar
Default Adding real dipstick to 2010 A4 2.0T engine
Anyone added a dipstick to their 2010 A4 2.0T? I just bought one for ~ $26. I removed the plastic plug that came in the top of the dipstick tube and inserted my new dipstick. Just one issue. At the top, right under the orange disptick handle, it's shoulder is a little wider than the widest part of the shoulder on the plastic plug. Thus, it doesn't want to go in perhaps the last half inch of the way to fully seat.
It looks as if the dipstick tube has some sort of soft plastic / hard ruber insert at the top. Perhaps I'm supposed to remove this plastic insert when using a real dipstick? Or, perhaps I supposed to just push down hard for the original insertion, forcing the soft plastic / hard rubber to "adjust" to the real dipstick's wider shoulder at the very top?
Anyone done this yet? Ideas? Suggestions? Surely I'm not the only Audi fanatic who wants a real dipstick in his expensive piece of German machinery!
Jim
Old 09-12-2010, 07:57 AM
iflywoe's Avatar
all i had to remove was the cap. where did you the dip stick from?
Old 09-12-2010, 11:18 AM
bondi's Avatar
Came from Boardwalk Audi in Plano TX. It's Audi part # 03L 115 611 M. What's the part number on your dipstick? It's located just under the handle on top -- very small and rather hard to read.
I did a bunch of internet research yesterday and it seems the most often recommended part # is 06J 115 611 E. This is supposed to fit as you describe -- just remove the plug that the car came with and insert the dipstick in its place. Voila. No muss, no fuss. Is this the part number you have?
Jim
Old 09-12-2010, 05:20 PM
Cabal_san's Avatar
I have and 06J 115 611 E and it fits quite snuggly on mine. Seems to read ok, but its been a bit since I checked. I will check tomorrow and see how far its diff from AMI reading.
Although, I have never really burned oil like some report on here and AZ...
Old 09-16-2010, 08:42 PM
dustbunny44's Avatar
Thanks for this. My dealer in Oakland ordered what they thought was a dipstick for my 2009, ended up being just the plug. Returned it of course, and I gave up. Will try again at some time, but am losing interest in the need to actually see my oil.
Old 09-17-2010, 04:51 AM
Old Dog's Avatar
Seeing is believing .
Old 09-17-2010, 04:52 PM
guertig's Avatar
Here's where I bought mine:
http://www.ecstuning.com/Audi-B8_A4-.../Oil_Dipstick/
Works fine, no issues.
Old 09-20-2010, 04:22 AM
bondi's Avatar
Had Boardwalk Audi (Plano, TX) order 06J 115 611 E as recommended here (after returning the first one that didn't fit right). 06J 115 611 E works fine -- fits fine and seems to read accurately (essentially the same as the MMI-displayed reading from the electronic sensor).
Many thanks to all for the recommendations and guidance.
Jim
Old 08-25-2014, 12:47 PM
power33's Avatar
SOLUTION!!!!
Just to let everyone know, I have an Audi A4 B8 2009 2.0TDI Engine, i have done my research just like everyone else about this annoying dipstick issue. My dipstick tube is located underneath engine cover with a plug.
I found a solution at long last!!!!
I purchased this dipstick which was perfectly correct for my vehicle on eBay- CLICK HERE
Now I can always check my oil level on both MMI and manually finally.
Old 08-25-2014, 12:48 PM
power33's Avatar
SOLUTION!!!!
MuHyC
21
03-31-2021 11:30 PM
a9094
9
04-14-2010 08:33 PM
mAgnum8
03-16-2009 11:04 AM
boxx
12
05-25-2006 02:03 PM
85urq
Quattro: Turbo / Ur / Sport
10-01-2005 02:17 AM
Quick Reply: Adding real dipstick to 2010 A4 2.0T engine
