Last edit by: IB Advertising
- Audi A4 B7 and B8 Door Lock Problem Diagnostics<br>Guide to diagnose trouble and recommended solutions.
Lock doors on started car/advanced key
#12
Yes, I get no response when I put the key in the door handle. I never use the exterior handle to lock my door and so now that I've tried, I noticed that it doesn't turn. I've jiggled and twisted and...........nothing. So it works for you? If so, you're the first I've come across who has been successful. Are you driving a B8?
#13
Again not to question you but the key only works if it's in the right way. I know it works. I've done it on both 2009s and 2010s. I had a client who would not buy the car if it didn't do it so they could lock their dog in the car while the car was running to keep it warm/cool.
#14
#15
The excess/long side should be toward the rear of the car. Make sure the key is all the way in. It will twist down to lock. You might want to try it with the car off as well to make sure you don't have a problem with your lock cylinder.
#16
Thanks a lot for the advice. I did try it with the ignition off and it still does not turn. I put the key in both ways and as far as it would go. It went in about 3/4 of the way. I am tentative not to do any damage. I am taking my car in for service this week, so I'll definitely get them to check it out. Thanks again.
#18
Finally warmed up a bit in Alberta and sure enough, my doors now lock with the external key. My locks were frozen shut! I guess I take for granted how much these cars are put through in the extreme conditions.
#19
Letting a cold car engine idle is actually worse for it than simply driving off. The manuals on both my current and previous Audi have warned about exactly this, insisting it's better to drive off at low throttle and keep RPMs down than to let the car sit and "warm up".
#20
FWIW my girlfriends mom's A4 was just stolen out ofh er driveway to let it idle. I know it's common sense to most (hence the desire to lock the car) but if you warm up your car every morning at the same time (before work) you're a very, very easy target. There was a huge spree in my parents neighbourhood, 6+ luxury SUVs stolen in a period of a week...
if anyone is unable to get the locking part to work (while they idle) then I'd suggest a remote starter.
