A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Tire pressure warning came on
Old 08-24-2014, 01:42 PM
djleder's Avatar
Default Tire pressure warning came on
Hello!
I was driving my 2014 audi a4 down the road today and all the sudden a low tire pressure light came on(it was yellow) while I was almost home. I got home and stopped in the driveway for a second and I went to the tire pressure monitoring section and it said all tire are at the correct pressure, and then the light went off. So I got back in the car and drove around the block a couple times and it did not come back on?
Could this have been just a fluke? Something similiar happened to my fathers bmw one time with the sensor? Should I take it in?
Thanks,
Old 08-24-2014, 02:01 PM
uberwgn's Avatar
when is the last time you verified your tire pressures?
Old 08-24-2014, 02:09 PM
Macallan21's Avatar
did you actually put a gauge on your tires and check the pressure? otherwise.. you have not "verified" anything.
Old 08-24-2014, 02:19 PM
djleder's Avatar
Never, this car has less than 4k miles on it driven pretty gently... I also have had a problem with a sensor already with the car so it would not impress me if it was again.
Old 08-24-2014, 02:54 PM
uberwgn's Avatar
Check your tire pressures. These cars are sensor-less.
Old 08-24-2014, 03:04 PM
djleder's Avatar
will do, by the way how does does a4 throw up these lights if it does not have a sensor?
Thanks!
Old 08-24-2014, 03:19 PM
uberwgn's Avatar
Originally Posted by djleder
will do, by the way how does A4 throw these lights if it does not have a sensor?
Audis have a sophisticated methodology of calculating when a tire is (has gone) going flat using the ABS sensor and some other inputs. IME, it's a slow-response system.
Please check your tire pressures against the values shown for NORMAL load in the rear of your Owner's Manual.
Unless you have a tire that is indeed problematic, you may need to do nothing more than adjust your cold tire pressures and re-store those values thru the MMI system. E-Z pea-zee!
ks7
11-05-2023 06:45 AM
gg948794478
A4 (B9 Platform) Discussion
02-23-2018 02:37 PM
olallaray
09-07-2017 07:43 PM
Xphstos
13
10-01-2009 10:28 AM
Emauss
17
07-09-2006 04:20 AM
Quick Reply: Tire pressure warning came on
