Power Steering Stiff / Can't Solved?
Power Steering Stiff / Solved!!
hi,
i have 2008-2009 Audi A4 1.8TFSI 135.000km vehicle. i bought it july 2015 as a used vehicle.
*1N1 - Power steering (Not servotronic)
And my car's steering whell is too stiff. its hard to parking etc. While driving its not problem, its heavy bu its like sport.
My Steering rack and power pump replaced at 2012 by previous owner. and i talked with him , he says "i changed but noting diffent. it still heavy/stiff. Don't replace to new pump "
i went to service first they tell it needs to replace "steering power pump" and "steering pump presure hose". i try just replaced the "steering pump presure hose" (because power pump is new.) (they didnt sad how much bar pressure, pump have)
after i went to service again they said pump is working normal, dont change everything is OK.
i went another service they sad also everything look normal. But really heavy.
and problem not solved.
i look VCDS, there is no steering preferences. (because of not servotronic)
*turning right and left, same stiff.
*while turn steering whell drive thru by self.
*not noise at pump
*not leaking, fluid is good (Fluid changed 3 times)
*Shock absovers (Front Suspensions) Changed.
*steering pump presure hose changed.
what can couses stiffing? service cant find?
Finally They sad this models like this. but i drove another 2008 a4 b8 1n1 they are too tight steering.
https://www.youtube.com/watch?v=c-Ea07BZTbQ&feature=youtu.be i add a video about situation...
This is normal?
(i'm out of usa. / bad english sorry)
*not noise at pump
This is normal?
I haven't tried one but heard others complaining about heavy low speed steering in cars without (at least) servotronic.
If there is nothing wrong and another car with the same equipment is the same, replace the car with one you like.
As a sidenote; B8 "facelift" (after model year 12/13) all versions have speed dependent servo assist but it is not called "servotronic" any more.
i can't find same equipment vehicle, every car which i looked has 1N3 Servotronic Steering. So i can't make comparison. if your car's has 1N1 Power Steering Maybe you will help me to its normal or anormal.
Perhaps I misundertood when you wrote "but i drove another 2008 a4 b8 1n1 they are too tight steering."
Sorry I can't help you compare. I had 1N7 i my 2008 and now I have 1N8.
actually i wrote it wrongly but no editing in this forum. (weird) yes i drove another 2008 a4 b8, the user says its normal standart power steering but after i understand its also 1N3 he didnt know (and i try to say light steering ). i still cant find any 1N1 steering vehicle...
I have the same problem on my Audi, same manufacturing year and engine. Everything changed, but stiffness is just there.
Could you please write down which steeeing pump have you put in, I'm searching a difference betwheen 1N1 and 1N3 pump and couldn't find any?
Thanks and happy new year 2023
Hello there,
hello, there is no difference between 1n1 and 1n3 pump, diffrence is steering rack. You need to just replace steering rack and put some electrical cables and open servo settings from vcds..
ofcourse if your present rack is non servo 1n1 rack, did you check your steering code is it 1N1.
Happy new year.
From my notes the How to Retrofit 1N1 Steering Rack To 1N3 Steering Rack
You need theese parts;
ZF 7831993140 = 490$ (i used theese part refurbished by ZF) or VAG 8T1422066B / 8T1422065P = 1600$
VAG WHT004711 x 2 = 5.7$
VAG 000979034E x 1 = 10$
VAG 000979016E x 1 = 2.5$
VAG N01116417 x 2 = 1$
VAG WHT004593 x 2 = 2.6$
VAG 4D0971992 x 1 = 2.8$
G 004 000 M2 x 2 = 25$
2.5meter 0.5mm cable - 2$
installation and coding - av 140$
+________________________________
Total = 680$
How To:
1- first cut 000979016E and connect 2 pins to pin 1 and 2 of 4D0971992.
2- cut again 000979034E and connect 2 pins to pin 1 and pin 12 of BoardNET T17l
3- Connect Pin1 of 4D0971992 to Pin1 of T17l via 0.5mm cable. &
4- Connect Pin2 of 4D0971992 to Pin12 of T17l via 0.5mm cable. and
5- Code Coding via VCDS VCDS - STG 9 Cent. Elect. - Long coding - Byte 7 Bit 0 to Bit 1
6- install New Rack and connect plugs and drive your vehicle with pleasure.
Total = 680$
How To:
