A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Stumbling A4
Old 07-19-2015, 04:47 PM
Rider3636's Avatar
Default Stumbling A4
I have a 2010 A4 that has a bad stumble/ misfire when given any more that alittle gas. It is smooth at idle or little gas. Ease off the peddle and it will settle out. Engine light is on. I changed the plugs and noticed that #2 was much darker that the others. I still have the same problem and have not run the car enough to read plugs to see if #2 looks like the source.
Old 07-29-2015, 05:15 PM
Cat Herder
pierreb's Avatar
Check the codes. You may end up having to replace leaking injectors, spark plugs, intake manifold, coil packs or all of the above. Good luck.
Old 07-29-2015, 06:41 PM
Rider3636's Avatar
After changing the plug I still had no change. I got the codes checked and it showed missfire on 1 and 3. After 4 new coil packs, she is running smooth again.
S929
10-19-2015 01:38 PM
1991audi200
05-12-2010 08:17 AM
Pekboy
03-09-2004 09:02 AM
CrappleZero
15
01-08-2004 08:13 AM
DrewP
08-13-2002 01:07 PM
Quick Reply: Stumbling A4
