$800 for 55k service
#32
Hmmm..... So your saying as a filter gets dirtier it works better? That contradicts everything I've learned in my 50+ years of wrenching pretty much anything I've ever owned that has a motor. My dad, who was a mechanic for over 35 years would get a great chuckle out of that statement!!!
I had a long talk with a Honda tech guy in California as to why they recommend changing their oil filter every other oil change and his answer was simply that all the tests they have run showed that oil filters became more efficient the longer they're in use(as long as they're not in bypass) and they've determined that optimal use was every other change.
This has also been corroborated on bobistheoilguy.com. So if you don't believe me then ask them as well but I stand by my statement.
As for transmission fluid, I've seen debris kicked up by fluid change to cause a failure first hand so I'll believe my eyes over anything else.
#34
You can make fun of it all you want but the larger particles that may have made it through when the filter was new are definitely not making it through now. The filter is definitely more restrictive when it comes to air flow but not nearly enough for it to throw a CEL. FWIW YMMV!
I do Used oil analysis on every oil change on every car I've owned since 2005 because it's just become a hobby of mine so I've literally done 100s of them and every single one I've done is posted at bobistheoilguy.com. one of the values they extract is for silicon (dirt) in the engine oil and the value always goes down in every subsequent UOA which indicates that the filter is getting more efficient with time.
#35
Very interesting discussion in response to my inquiry about the air filter change interval, thanks! However, I'm more confused than ever -- LOL. When I have time I'll do some research on this subject and dshahs assertions in particular and report back if anything worth reporting.
Best
Jeff
Best
Jeff
#36
Hi everybody. A quick update. I ended up going with the Audicare $819 for both services. I appreciate your advice as my service advisor probably wouldn't have mentioned it (yet he was completely aware the option existed when I mentioned it). I think it's worth it given it covers both services, a loaner, my car looks like new when I pick it up, etc.
Thanks again for all your help!
Fujing21
A4 (B9 Platform) Discussion
10-24-2016 10:40 AM
