12V Lighter Fuse
Old 08-14-2014, 10:25 PM
DasA6's Avatar
Default 12V Lighter Fuse
Long story short, the A6 was used as a diagnosis vehicle but was inevitably the victim of a bad car charger...
So my question is, where could I find the luggage compartment fuse panel? The manual says it is on the right side after you take off the trim, but after taking out the tire and staring at the car, I am still perplexed. My research has come up with plenty threads saying it is on the right side......but I CANNOT find it! Pictures would be helpful as well.
Old 08-15-2014, 02:59 AM
DirkM's Avatar
You can pull put the storage compartment on the right. There is a fuse box behind/below that compartment. Pull slowly the cable to the 12V socket is short.
Old 08-15-2014, 05:12 AM
Richard Solomon's Avatar
Look up "Fuel filler flap emergency release" in TFM, it shows how to remove the trim panel.
Old 08-15-2014, 10:18 AM
DasA6's Avatar
Found the cubby, should I use a flathead to pry it open? Couldn't find your info Richard.
Old 08-15-2014, 02:24 PM
I wouldn't! The manual mentions unlocking the latches by turning them 90deg to the left with a coin or similar.
In the 11.2013 version of the 2014 manual it's page 220, check your index under "F" then "Fuel" and then "Fuel filler flap emergency release".
Old 08-15-2014, 03:06 PM
DasA6's Avatar
Thank you very much. That fixed it, now all are working. Vielen dank!
PeterWolf
01-04-2020 07:11 PM
RSDodd
06-15-2017 01:30 PM
nate704
Q5/SQ5 MKI (8R) Discussion
10-21-2015 06:33 PM
theaff
10-15-2010 02:08 PM
fairenough
11
01-30-2002 01:58 PM
Quick Reply: 12V Lighter Fuse
