55,000 miles - Spark Plugs and V-Belt
I'm approaching 55,000 miles and I like to do these services myself. I am going to change the spark plugs and V-belt and have some questions:
1. Spark Plugs - Should I change the coil packs as well? I'm from the school of "if it isn't broken don't fix it" but sometimes the extra maintenance is recommended.
2. V-Belt - I have searched here and on YouTube and can not find any info on how to change this belt. Does anyone have a DIY?
3. V-Belt - Are there any other replacement recommendations like tensioners or whatnot to go along with this maintenance?
Any info is appreciated.
Here is a diy for a C6 pulley, might help with the vbelt it may be similar.
https://www.audiworld.com/forums/a6-...ulley-2884201/
there is a diy for plugs on the C6 forum as well it might be worth a look
1. Spark plugs. Don't change the coils unless they fail. You might want to keep a spare coil in the garage for replacement or testing.
2. Maybe YouTube has one or check in the C6/C5 sections.
3. Most tensioners should make it to 100,000 miles. The spring weakens and the belt will squeal on the alternator after start up.
I am not sure if you need to keep a spare coil pack for 3.0 C7s. The diagnostic computer is so sophisticated, VAGCOM will tell you which coil is bad.
I use the 3M silicone grease for many things - including brakes. 3M 08946 Clear Silicone Paste - 8 oz.
Replacing the accessory belt so soon? (I assume that one and not the Supercharger).
I assume you have already done air filter
I'm about to do the V-belt soon as well, since I too am approaching 55k miles. I also just posted a DIY on the spark plug replacement - pretty straightforward. In fact, I changed the plugs on my wife's Mazda CX-9 a week later and they were much harder to replace.
As said above, leave the coilpacks alone until they fail - they used to go often on my old 2002 A4, but once they got the recipe right they lasted several years.
I'll probably get to the V-belt replacement next weekend (I hope). I'll try to take pics and post a write up afterwards.
-Mark
-Mark
I bought both, so I'll probably replace them both at the same time to save the hassle next year.
-Mark
I was originally confused about this, but the schedule calls for the supercharger belt to be replaced at 55k and the accessory belt at 75k. But it refers to both as a V-belt... you have to read closely and note which is the "front" V-belt, and which is the "rear"...
-Mark
-Mark
I had the rest of the 55K miles maint. done last week.
When the plugs were changed, I got an immediate >10% increase in MPG.
I am having the front belt changed this week (at (every) 55k miles) it says:
"– replace only the belt for the compressor drive (front belt)"
The other (rear belt) looks like every 75K miles.
Lasting 90-100k miles is different than performing their best at those mileages. I have found that all plug gap will widen over time. I just did mine at 98K and assume they would have been done already.
On the belts, personally.. I plan on buying both belts and tensioners because I found the belts on mine to be Dayco and that's not cool in my book. Next time I put the car into Service Position... I'm doing a solid bit of work considering the effort it takes to get into Service Position.
