anti-dazzle outdoor mirror
Hello
I have anti-dazzle interior mirror, I have switched to anti-dazzle glass in the exterior mirror and pulled the cable to the control unit in the door, what more do I need to do to get the automatic dimming of outdoor mirrors?
Thanks in advance!
Thanks in advance!
Club AutoUnion
I have previously done this retrofit on a MY11 TT. If you have run the dimming signal wires from the mirror down to both doors and into each control module, then you must replace the small harness that goes from the control module up to the mirror glass itself. No coding should be needed as the control modules usually just act as a passthrough for the dimming signal.
Club AutoUnion
8 Pin Interior Mirror connector > 27 Pin Door connector > 20 Pin Door Control Module Connector > 16 Pin Control Module Connector > 2 Pin Exterior Mirror Connector.
Thank you very much, Mrclopec
I will try this when I get time.
Do you know which pin is used in the various contacts, especially in 8 pin contact in interior mirror?
Club AutoUnion
Mrclopec (07-17-2023)
