Chirp when locked/unlocked
Old 03-07-2014, 05:29 AM
A6-UK's Avatar
Default Chirp when locked/unlocked
Hi, new A6 S-Line Black Edition owner
Quick question, Is there any way to enable a audible lock/unlock tone
(UK owner, if it makes any difference)
Old 03-07-2014, 05:51 AM
DB22's Avatar
It is interesting that a UK owner wants a chirp. It is the only audible warning that is not insulting to the owner and is quite useful. Here in the US we have chirps and dongs and all kinds of noises to tell the driver that his lights are on, his door is open, his seat belt is not fastened etc.. I remember Jeremy Clarkson being annoyed/insulted by American manufacturers that assume that drivers are too stupid to operate a car.
To answer your question, the VAG-COM interface will enable a change to 2 chirps for unlock and one chirp for lock. Mine has one chirp for both but I do not know if the chirp on off is selectable, I'm sure that somebody with more VAG-COM knowledge than I will "chirp" in.
Old 03-07-2014, 09:12 AM
r1racer's Avatar
Yes, you can turn the chirp on/off.
Old 03-07-2014, 09:18 AM
gatorguy7's Avatar
I thought this was a setting in the MMI, not VAGCOM.
Old 03-07-2014, 01:47 PM
dicktahoe's Avatar
According to the manual it is in the MMI. Select the "Car" button, then "Systems", then "Vehicle Settings" Go to "Tone When Locking" and set to ON.
Old 03-07-2014, 02:05 PM
A6-UK's Avatar
That option is not visible
Old 03-09-2014, 09:34 AM
Richard Solomon's Avatar
Step 1: Buy a VCDS setup from Ross-Tech: http://www.ross-tech.com/
Step 2: Visit one of several tweak sites...
a) http://www.audienthusiasts.com/VagCom.html
b) http://www.vwaudiforum.co.uk/forum/s...C7-VCDS-Tricks
Step 3: Apply the tweak(s) of your choice.
Step 4: Enjoy!
FWIW, it appears you need this one:
Code:
Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
 [Select]
 [46-Central Conv.]
 [Coding - 07]
 [Long Coding Helper]
 Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
 Check this option
 [Do It!]
Old 03-09-2014, 09:41 AM
DirkM's Avatar
The chirp is only possible if you have the factory alarm system.
Old 03-09-2014, 10:29 AM
Makes sense - are A6 models in the UK sold without the factory alarm?
Old 04-06-2016, 01:07 AM
Banned
asadani's Avatar
How would I know if the version of mine has a factory alarm. The dealer said that it is not possible. The only way to know is to test it out.
Quick Reply: Chirp when locked/unlocked
