Vag com
Old 02-23-2017, 01:44 AM
kevrhof's Avatar
Default Vag com
I've been trying to figure out some info on this but can't really find any so I figured I'd just ask.
I'll assume that different vag coms do different things, which is the most popular brand here?
There are a couple customization things I'd like to do, like lower windows with unlock and be able to raise and lower the idle rpms. Any help with what I need?
Old 02-23-2017, 01:52 AM
19hole's Avatar
The Ross-Tech cable and software will be the most comprehensive, and the most expensive, solution to the VAG-COM question. It can do pretty much anything to your car, which is both good and bad. They do have a great support forum.
Old 02-23-2017, 04:58 AM
dc2002's Avatar
Yes I agree that Ross Tech is worth the investment...
Looks like the USB cables are back with an option for 3 VINs(199) or 10 VINs(299)
I dont remember that option when i got mine - 349 for unlimited VINs.
Thats basically 2 diagnostic visits...
Old 02-23-2017, 05:57 AM
kevrhof's Avatar
Does the rosstech allow for idle speed adaptation?
Old 02-23-2017, 08:44 AM
DB22's Avatar
I'm curious as to why you would wish to change the idle speed? The computer will vary the speed according to a lot of input from sensors and is dynamic.
Old 02-24-2017, 01:04 AM
kevrhof's Avatar
The original dealer changed the idle speed for whatever reason, I believe they were having issues managing the secondary air system. So I'm curious if vcds would allow me to change it as well
Old 02-24-2017, 01:37 AM
hotlips's Avatar
Default Vag - Ross Tech
Curious, does the number of VINs mean cars it can be used on, or, number of times one uses the vag on one car?
Old 02-24-2017, 02:09 AM
19hole's Avatar
It means the number of different cars you can use it on.....
Old 02-24-2017, 04:50 AM
snagitseven's Avatar
New VCDS OBDII cable model with new use options (HEX-V2 Enthusiast). Adds compatibility for the newest Audis.
Old 02-24-2017, 01:39 PM
kevrhof's Avatar
So any thoughts on changing the idle?
Quick Reply: Vag com
