Heated Sideview Mirrors and AutoTilt
I have been trying to get this question answered and have received conflicting information. In regard to this question, the manual is unhelpful.
I am resigned to leaving my mirror switch set to Passenger Side in order to keep Auto Tilt always available. That's actually a pretty ridiculous programmatic requirement but it is what it is. But, the question. ... are my Sideview mirrors still heated even though the switch is not centered.... and centered has a mirror heat icon. In most vehicles, centered means the switch is neutral and if you bump it, you don't screw up your mirror settings. But in Audi, is there no heat unless centered?
AGE
AGE
AGE
AGE
Then you can turn it towards the passenger mirror.
So the confusion comes when the manual reads that the heaters are external temperature sensitive. Nowhere does it state that you need to center the switch and push it towards the bonnet to activate the heaters. One might assume that all you need to do is center the switch and when it's cold, they'll heat and when it's not cold, they wont.
So what you are saying is that center, push towards bonnet, then turn to passenger mirror adjustment position... and simply leave it there and the mirrors will heat and the auto tilt will tilt?
AGE
AGE
That's correct - the mirror heaters are automatic based on outside temp. Pressing the mirror button does absolutely nothing (except ejecting the salesperson who said it would from the passenger seat when on a test drive). The passenger mirror tilt occurs when the selector is turned to the passenger side and the car is placed in reverse. That makes sense as you wouldn't always want to have the mirror til down when backing up except when parallel parking next to a curb.
Snagitseven - So what you are saying is that mirror heat is always on at and below some unknown external temperature irrespective of switch position. OK. As for tilt, I find it useful for more than parallel parking. I programmed it to also tilt away a bit which gives me a better view of my right side garage door opening, the car next to me in a lot, small animals and children...
Tomorrow I will test it using high tech tools called "hands." And an IR Thermometer.
