Homelink
Homelink
I have programmed my 3 buttons on the Homelink interface and I wanted to point out that the programming sequence is the best, slickest system that I have ever used. My other cars have needed help or even a phone call to get programmed but the A6 is very well designed and interfaced via the MMI.
I do not like the ugly remotes hanging on the visor and I like the clean implementation of the feature. Does everyone use it and have you ever seen a better interface than the MMI for Homelink?
DB22, i followed the instructions on the homelink website and also via mmi to program my garage door. I have not had full success.
I will say i did wipe all the buttons and programmed it again according to the homelink site and will see if it works today.
I will update here if it doesnt and see how you got it going. I have a rolling code chamberlain door opener.
I programmed via the remote - I followed the bouncing ball in the MMI for button 2 and then walked around the front of the car and pointed the remote at the rings from about 6 inches away. Holding the remote button for 10 to 20 seconds the DRL's flashed 3 times indicating that the code was accepted. This was also Chamberlain rolling code. I also programmed a security gate the same way. Unless you are at the door in question then you cannot answer the question as to whether it worked but I said yes anyway and then drove to the gate and garage door in question and they both worked.
To program i followed similar instructions to you, i set button I in program mode held my garage door opener fob at the rings and held it until i saw the 3 lights and then pressed the I button twice. Once that happened i set the chamberlain into learn mode and went inside and pressed the button twice to learn it.
Initially when i did just the fob pressing part and no learn from garage door opener the door opener worked for half a day or so and stopped and later i found i have to hit the learn button for the car to adapt the rolling code.
Hopefully its working as when i left yesterday it worked just have to see if it continues to work.
Have to agree with the OP. Easiest I have programmed over my last 4-5 cars. Didn't even need to touch the learn button on the opener itself. Done and done in under 2 minutes total.
Update: If i press the button once it doesn't really open the door, I have to press it again to open it OR i have to hold the button down to open it (separate occasion).
Is this normal behaviour or should i wipe and start over again?
