How to replace 3.0T spark plugs
#11
Okay, took a look. Unfortunately, the tank is going to have to be drained. Theres no way to get it out of the way with that hose on the bottom, so unless you can somehow cap the top openings, and flip it over so you can remove the lower hose with it upside down, I don't see any way to do it.
#12
Incidentally I replaced my plugs with Denso 5303 IK16 Single Iridium Spark Plug. These have a gap of .044. It would appear the NGK stock plugs have a gap of .032. Based on as much info as could find these Denso plugs are a colder plug from the stock NGK plugs. A short test drive did not show any adverse effects but I will be tracking the car this weekend. So I shall see if I encounter anything unusual.
#13
Coolant Level Sensor Connector
Jr/Anyone who's done this:
Did you happen to disconnect the coolant level sensor from the harness when you moved the overflow tank? What's/where's the magic push or pull thingy that releases the connector?
#14
I also removed the entire coolant reservoir. Stick a small tube in it and drain the coolant into a bucket while you work on the passenger side plugs. If the tube is small enough, you can slide it down the hose at the bottom. When the reservoir is empty and you have the sensor unplugged, remove the three hoses by sliding the clips out and remove one torq screw.
Pictures are in this thread.
https://www.audiworld.com/forums/a7-...hange-2917832/
#15
I did disconnect the sensor connector from the bottom of the reservoir, but I did not drain it. The connector was a little hard to remove, but mostly because it gets a lot of moisture and dirt. A bit of wiggling while the tab is pressed and it'll come free. I also unclipped part of the coil pack harness to make it easier to move around.
-Mark
HACK THS
01-11-2005 03:03 PM
TwnTrbo
18
07-20-2003 09:01 PM
