Key Fob battery and replacement
Old 03-22-2013, 01:44 PM
JML - TX's Avatar
Default Key Fob battery and replacement
Surprisingly, the battery in my key fob needs replacing already, as the center dashboard display indicates the battery is weak everytime I start the car. I am kind of surprised that the battery is dead after less than 2 years, as I rarely have ever replaced batteries in key fobs. At any rate, does anyone know how to open up the fob (is for a prestige, so not sure if they are different for different models or not)? I do not see any obvious way to gain access to the battery, though I am sure it is probably pretty straight forward. I do not want to break it though, as that would be a costly lesson. thanks.
Old 03-22-2013, 03:38 PM
mikem33's Avatar
Very easy.
1- Remove key.
2- 'Pinch" silver button and little tab on the backside of the button. Pull.
The assembly will come out.
3- Replace battery.
Done....
Old 03-22-2013, 09:23 PM
z06bigbird's Avatar
Originally Posted by mikem33
Very easy.
1- Remove key.
3- Replace battery.
Done....
Or
Try a little electrical tape on the "dashboard display that shows..." (probably a temp solution) lol
Old 03-23-2013, 05:39 AM
JML - TX's Avatar
Very easy.
1- Remove key.
3- Replace battery.
Done....
Thanks for the directions, it was quite easy. The best part was I even had a CR 2032 spare battery on hand....very quick and easy.
Old 06-22-2013, 05:21 AM
spoon2000's Avatar
Very easy.
1- Remove key.
3- Replace battery.
Done....
Thank you -- that worked really well.
FWIW don't waste your money on an overpriced replacement battery at the dealer or at Radio Shack -- you can get CR2032 batteries VERY cheap on eBay or Amazon, and if you order some when you first get the "replace key battery" indication, they should arrive in plenty of time.
Old 06-22-2013, 09:01 AM
tenspeed's Avatar
I got a dozen of them from eBay last time. They're around $.25 each.
Old 11-27-2015, 08:13 AM
Redd's Avatar
Bless you, Mike! Totally unobvious way to get in there and pop the battery out.
Old 11-27-2015, 09:51 AM
porksoda's Avatar
Just fyi on the 14 i had my battery expire on me. I am suspecting i keep the key in my front pockets and the buttons are being depressed.
Old 11-27-2015, 10:13 AM
Redd's Avatar
That's what you get for wearing pants with pockets, instead of a proper kilt with a sporran.(G)
Go to the dealership, and in the gift shop ask them for a proper kilt in the Audi Clan tartan. Honest. (WEG)
Old 11-27-2015, 11:36 AM
porksoda's Avatar
Heh kilts would be a bit cold up here in the great white north... but you gave me an idea to look for a fob cover/pouch/case!
Louis3.0A6
A6 (C7 Platform) Discussion
11-19-2014 02:50 PM
Xenon
Q5/SQ5 MKI (8R) Discussion
01-09-2012 10:14 PM
greyjag
01-30-2011 06:58 PM
Need4S5
10-07-2009 12:49 PM
chuckleb
01-05-2001 09:05 PM
Quick Reply: Key Fob battery and replacement
