MMI Software question
#11
This past week I received a 0715-2 update which is from what I understand the latest update available. And it did make a big improvement in the quality of the sound system from the earlier version I had. From what I've gathered, new cars currently have the 733 version installed. Not sure what the difference is.
#12
For what it's worth, I found and purchased this MMI update disc from ECS for my 2012 A6 prestige: Search SiteSearch 8r0906961cl - 8R0906961CL - CDROM - ES#2684120
Delivered, it was $16.
It is for version 715, which I know isn't the newest (especially 8 out last week). I'm planning to install it myself. I have a charger to hook up to the battery during installation like everybody has mentioned.
I only have one question about an MMI update: does anyone know, or can you provide a link to, if MMI needs an activation code similar to the nav updates?
Thanks!
Thanks!
#15
I would be very careful
Here is some instructions
But I have heard horror stories about upgrading/updating MMI software by the dealer and somehow messing with it and some ECUs needed to be replaced (obviously because the dealer did they covered it)
#17
I had my car into the dealer for the recall fix and TCU update and finally got them to do an MMI update to fix the problems I have been complaining about. During the MMI update something happened that has resulted in having to replace the MMI unit (F5), I think that is the designation they used.
#19
Hi again,
I attempted the upgrade yesterday afternoon. I am video recording all of my attempts in case I need to review any steps I took and also so I can post it later if it all works out.
After inserting the disc and and selecting software update, it begins scanning the disc. For a very short half-second, the screen shows an option to start the upgrade/update that quickly disappears. Another message then displays saying "No Update Device Found".
I'm still researching to find out if I need to do something differently. I did find a post describing that I need to use the Engineering Update menu, which can be accessed by pressing CAR and BACK at the same time. I am unable to get this menu to load. The green menu loads just fine. If anybody has any info on which page I need to be on to access the Engineering Update menu, I would appreciate it if you would pass it along. The green menu only loads after pressing CAR, the MENU, then CAR and MENU.
Thanks!
Thanks!
#20
Not sure how helpful this is. Here's a thread from a 2012 A7 ROW owner that upgraded his MMI software. https://www.audiworld.com/forums/a7-...770-a-2864827/
I'm also thinking what you are calling the engineering update menu is the hidden menu that needs to be enabled with a VAG-COM.
