Truphone - please help
Old 11-06-2013, 05:24 PM
SmokingTires's Avatar
Default Truphone - please help
After a long saga of lost SIM cards and account activation errors I finally got a working SIM card and was able to activate it online (or at least I think it activated it). Now I inserted the SIM card into Audi's slot, got the 3G symbol and attempted to go online. (I have no way of checking SIM card otherwise, since all my phones are Verizon with no SIM slots).
First it told me to turn on "data roaming", which I did. But after that it still told me "unable to make connection, try again later". The signal strength is 2-3 bars (medium). Should I change any settings? It does say "vodaphone.nl".
Those whose were able to get Truphone to work, please let me know what you had to do and what your settings are.
Thank you.
Old 11-06-2013, 06:07 PM
snagitseven's Avatar
I thought the APN for Truphone should be "truphone.com" with user and PW left blank (might need a space on either of these if blank doesn't take).
Old 11-06-2013, 06:32 PM
Thank you! This helped. I was able to get the data connection working, but it's showing 2G, rather than 3G. When I had T-mobile trial period it was working at 3G. Now with Truphone it's connecting via ATT network (at least that's what it says).
In your experience, are you able to get Truphone to work in 3G? What did you have to do?
Old 11-06-2013, 06:46 PM
It is trying to connect to the AT&T network which will only work in 2G with a T-Mobile sim. Turn roaming off, remove the card and reinsert and see if it shows T-Mobile. (Obviously, you need to be in a T-Mobile 3G area or it will still show 2G).
Old 11-07-2013, 05:41 AM
Snagitseven, thank you very much! It wasn't as simple as reinserting the SIM card, but it worked. I tried reinserting the SIM card, then I changed the APN from truphone.com back to T-mobile (m2m.t-mobile.com), but that didn't work. Then I changed the APN back to truphone.com and at that time it worked.
I tried Google search and worked well. I don't need Google Earth, so my data costs will be low. Google Search is simply awesome and sending destination to my car also is very cool.
Old 03-31-2014, 04:15 PM
Gator Neil's Avatar
So, I ordered the Truphone SIM. It works fine, but only will pick up 2G as the only network it wants to connect to is AT&T. To get 3G, must be connected to T-Mobile. I asked Truphone tech support about the issue and they suggested taking the SIM out, putting it in a phone, select T-Mobile 3G network, register it, remove and put back in car. Didn't work. When I informed Truphone, they sent this reply:
I am writing on behalf of my colleague Nuria. We have just got a reply from our technical team regarding your issue. If the sim card connects and works properly in your mobile device it means that there must be an issue with Audi system. However there should be a way in your Audi system to manually select the T-mobile network. In this kind of situation you should contact them in order to receive proper assistance.
If you have any other questions, don't hesitate to contact me.
Have a great day,
Kind and warm regards,
Bartek,
Truphone Expert
So does anyone know how to get this SIM to connect to T-Mobile?
Mitchmark00
A7
10-02-2016 06:44 AM
dougpaper
A6 (C7 Platform) Discussion
10
12-20-2015 04:31 PM
A IS FOR AUDI
03-30-2001 07:02 AM
Quick Reply: Truphone - please help
