Sat Nav woes
#31
Yea its slowly coming together for me, I am starting to get it! Overly complicated, but I suppose more options is better than less.
Does anyone have experience of using iPhone contacts for navigation, I have not tried this yet as to be fair I don't have many addresses against contacts, but would probably make the effort if it works.
Unfortunately, the main constraint is the parser. In my case the parsing fails if I have an apartment/suite number in the address or anything else other than house number and street. In cases where the parsing fails it still recognizes the city, but I have to manually enter the street and house number before saving the navigation destination. Minor inconvenience, but once the navigation destination is stored it just works.
The more annoying part is that once you parse an address and save it, it creates a shadow copy of the contact in the MMI's directory and it links that shadow contact with the contact coming from your phone. That's all good until you update some of the data for that contact on the phone. At that point it breaks the link and you end up with a duplicate contact in the MMI. It's easily fixed, though, by just deleting the shadow contact. It has a different logo next to it, so it's easy to recognize, however, after that you have to parse the address again if you want to continue navigating to that contact's address.
It generally works pretty well for me. I don't have many contacts that live in apartments and my contact data doesn't change that frequently for existing contacts. I mostly add new contacts.
One other question, how are people getting on with traffic data?
On my BMW it would offer a detor if the current direction of travel had issues up front, this one seems to inform there is **** ahead, but I cannot see any options anywhere to offer me another way.
Also on the cheapest tomtom nav, you can specify to avoid a road on the journey, for instance if you know that there is something ahead that you want to avoid. A case in point roudn this way last week was 'dorset steam festival' which has one main road in which is totally and utterly chocker for two days. On a tomtom you would just say avoid part of route and select that road, boom its avoided.
I am supposing my ultra expensive satnav option pack has no such options?
One other observation, it will kindly tell me about traffic and issues on roads that have nothing to do with my journey in my field of view dash, why?
As for avoiding certain streets, that's not an option, but you can tell it to avoid the next x miles of your current route, which is somewhat similar. An alternative is adding a stopover to your current route that will cause it to route you around the problematic area.
EDIT: You have to enable dynamic rerouting in the navigation settings. I believe it's turned off by default.
#32
Another annoying thing is when you arrive at your destination it simply says you have arrived. It should display the address without fumbling through menus to find it again. The last few hundred yards are now a mystery of where to stop.
#33
Using Google Earth/Audi Connect, it displays a photo of the destination as you approach. I found that to be quite helpful!
#34
#36
You should never input your exact home address into your NAV. If someone has your car they now have your exact address and your garage door remote.
#37
Much more risky to have one of the old fashioned remotes clipped to your sun visor. Then somebody can just break in, take your registration and the remote and walk up to your house. Now if you are concerned that a sophisticated hacker gets a hold of your car and manages to boot up the MMI, then simply go into the settings and enable encryption to encrypt all the data stored in the MMI.
#38
It's certainly way more convenient to pull into my garage than to park two blocks over and walk in to "thwart" any robbers
FWIW, the door between my house and garage is locked unless someone is passing through it, so I hope the SOBs don't take all my car care products too! Oh wait, they got my keys at gunpoint also there go my etchings.
#40
Best I can tell, being in the USA, if you enter/edit them from the web with the full address including the zip, it will parse correctly. Doing it from my Android phone was hit and miss. A partial address seemed to mess them up and put the whole thing in the address field.
When you go to gmail.com and into contacts, click the three little dots ... next to the address and check to see if they are formatted correctly.
