Slight shimmy-like sound from dash/engine bay at highway speeds
Hi all,
Have a '14 TDI Prestige package with about 25k miles on the clock. I've noticed that, when the radio is muted and HVAC fans are off, I can hear a slight shimmy/buzzing like sound coming somewhere from the front of the car at highway speeds. The pitch appears to increase with pitch and the sound appears only at speeds over 45-50 MPH.
Anyone else experienced something like this? It's very light - I can barely hear it with my head turned and ears pointing towards the dash... but it's there.
Thanks!
Thanks!
No oil leaks; mounts seem to be OK. I've also discovered, completely by accident, that when I adjust the steering wheel using the joystick, the sound goes away! Perhaps PS related... anyway, gonna head to the dealership on Friday and have them check it out.
Update:
Took the car in last Thursday and got me a Q7 TDI as a loaner (what a comfortable yet outdated boat!). Today I got the call - appears the noise is originating from the PS rack-n-pinion and resonating up the steering column which explains why the sound stops when I adjust the position of the steering wheel.
In any event - ordered a new rack-n-pinion system and hopefully will get my baby back on Thursday!
So - $3,500 and a new steering rack later (all done under wty of course) - the sound is still there.
Can someone with another '14 TDI try and test it out for me? The conditions are as following:
* Speed over 55 MPH
* No HVAC or Radio (it makes it easier to hear)
* Turn your head towards the dash of the car and check if you can hear a buzzing/shimmying sound.
* If you do hear the sound - use the steering wheel joystick control to adjust the position of the steering wheel; the sound should go away as you move the wheel and return the moment you stop.
My dealership will do the same.
Thanks!
* Speed over 55 MPH
Thanks!
Would love to help, but, I'm a poor premium plus owner without the steering wheel adjustment. I'm not sure what a "shimmy" noise is. I do hear a "gear" type noise that does change based on speed notable at freeway speeds, but, it's always been like that -- assumed it was the quattro.
Another way to describe the noise would be like background buzzing noise you'd hear while listening to AM/FM radio or talking on a walkie-talkie. It changes in pitch... it almost sounds like a flying insect or something along those lines.
My issue is more of a "rubbing" that I hear and feel sometimes through the steering wheel. It's very slight and not always there (more so with summer temps) and it frankly hasn't bothered me much. I'll probably get around to have them checking it out and see what they say. I read where others having the same issue had the steering rack replaced but it came back.
Even a lowly Premium Plus can help
