why no crisscross rotation on quattro?
the manual indicates the rotation should be front back, same side only. any idea why it is the case?
I am not using directional tires.
Good question! I'm planning to get my tires rotated around lunch, so any insight would be good. Audi's differential system isn't as finicky as some other AWD cars that get really upset if you have much tread difference between them.
If you get your car aligned, it shouldn't matter (or at least I don't know why it would). In my C6 with full-size spare, I would do a 5 tire rotation.
It has to do with the steel belts in the tire setting in one direction and if the rotational direction of the tire is changed, belt separation may occur. Different tires are more or less susceptible to this, so the safe rotation pattern is front to back so the tires rotate in the same direction over their entire lifespan. Pirelli for example recommends front to back rotation of their tires. So, if you criss-cross, check with the tire manufacturer first if belt separation is a concern for your particular tire.
https://www.pirelli.com/asset/index....idelement=5810
IMHO it may be just because front to back is the simplest effective solution and covers directional tread tires.
Ever since steel belted radial tires were introduced years ago, it has been recommended to rotate front to back, same sides. While a belt failure could be uncommon, reversing direction can warp the belt introducing shimmy vibrations that can be difficult, if not impossible to correctly balance and can affect true tracking of the tread.
Been there, done that.
Sorry but I'm doubtful. No manufacturer would risk someone not following a recommended rotation pattern and having belt separation failure occur. Especially since they can't even win the battle of putting responsibility on the owner for proper tire inflation. (Hence TPMS in every car.) Plus from the Pirelli website they indicate switching sides if the size is different front and rear so that puts the manufacturer belt separation risk out.
Any tire shop worth their money will reverse the tire on the rim if they rotate side to side in order to preserve the rotational direction. Obviously an absolute must if the tires are directional. Reversing the tire is not always possible, because some tires like the P Zero for example have a dedicate inside/outside thread design.
The gist is front to back is always safe provided the tires are the same size. If rotating side to side you need to know what you are doing and if the tires are not reversible than you shouldn't rotate side to side.
thanks everyone.
here is the story:
when I was on my way home, the tire pressure alarm sounded, I ignored it, kept driving for about 3 miles till I get home, not knowing what had happened.
the next morning, driver side rear tire is flat, and only then I realized I hit a nail.
the tire has some damage on the sidewalls.
I hope the rim will be ok.
I'll do the rotation as suggested.
here is the story:
thanks everyone.
here is the story:
here is the story:
