Winter wheels
Winter wheels
I am thinking about getting winter wheels. The Tire Rack website says this: This vehicle relies on the wheel speed sensors in the hubs to monitor the tire pressure differences. Although no tire sensors are required, a TPMS reset is required so the vehicle learns the new tire overall diameters.
Is this reset something I can do myself, or do I need the VAG cable thing to do this?
Thanks.
Thanks.
No tools, and no VCDS cable/software required. It is a simple procedure performed using the MMI. As others said, quick and easy to do. IIRC it is under "vehicle settings" but I would need to confirm that.
Tire Rack Tires
Last week I received a set of 4 Blizzaks 245 - 45R-18 mounted on new rims from Tire Rack. They worked great and all it was was a reset in the MMI. I did have trouble getting the stock rims off because of sticking . All you do is loosen the lugs 2 turns on one wheel at a time and reverse slowly and hit the brakes and it breaks the corrosion seal.
Northern Goat
10-08-2018 05:41 AM
BlackS42005.5
12-26-2006 10:29 AM
