'01 A6 A-Pillar Removal (long) w/Pics
Old 07-14-2002, 08:17 AM
New Member
jimljewel's Avatar
Default '01 A6 A-Pillar Removal (long) w/Pics
This all started because I wanted to hardwire my Passport 8500. That being said, I searched the Tech pages, and I read my Bentley Publisher Service Manual. I was ARMED with information to remove that A-pillar trim! Basically, remove the grab bar, and pull trim from pillar! Gee, how easy is that! WRONG! The upper clip, near the top of the windshield is not like the other clips. It has a special retention system which needs to be undone prior to removing the trim piece.
Below are more detailed instructions and pictures.
So, lets get started. Wash your hands! The cloth will pick up any grime on your paws!
BE VERY CAREFUL NOT TO TWIST OR BEND THE TRIM. It will wrinkle the material underneath and you will lose that smooth cloth look.
DON'T USE ANY SHARP OBJECTS TO POKE UNDER THE TRIM. You might damage your airbag.
(If you are worried about potentially deploying your airbags, disconnect the ground terminal on your battery).
Gently pry off the AirBag Cover at the top of the B-Pillar with your fingers or small screwdriver. Under it you will find a Torx screw. Use a T-25 Torx screwdriver to remove the screw.
<img src="http://pictureposter.audiworld.com/29770/ab_cov.jpg">
Then remove the Clothes Hanger Clip just to the left of the Airbag cover. You will need Philips screwdrive to remove the clip. Behind the clip is another Torx screw (T25). Remove it. It should look like this.
<img src="http://pictureposter.audiworld.com/29770/bpil_clos.jpg">
Note that the A-Pillar Trim Retention piece sits UNDERNEATH the rear trim piece. This is why we had to loosen up the rear trim piece.
Next pull down the grab bar to expose the screw covers. Gently, pry the covers towards you, with with a pick or your finger nails. This will expose two more Torx screws (T25). Remove them.
<img src="http://pictureposter.audiworld.com/29770/gbar.jpg">
To make things easier, remove the driver's sun visor. GENTLY remove the screw plug to expose the Philips screw underneath. Then CAREFULLY pull out the bracket and wiring harnesses.
<img src="http://pictureposter.audiworld.com/29770/vis_att.jpg">
Remove the cloth electrical tape between the brown harness and the visor. Then gently pull apart the plug from brown harness and also the plug from the black harness attached to the visor. BECAREFUL to support the visor and NOT put too much strain on the wires. You don't want to RIP the wires out of the blocks.
<img src="http://pictureposter.audiworld.com/29770/visor_det.jpg">
Now comes the fun part! The upper clip of the trim has a special retention clip. The clip is meant to be inserted, but not removed UNLESS you remove the retainer holding it to the trim. This is what it looks like from the INSIDE.
<img src="http://pictureposter.audiworld.com/29770/clip_clos.jpg">
Notice the little cable attached to the clip? The cable goes to here.
<img src="http://pictureposter.audiworld.com/29770/cab_ins_clos.jpg">
The whole thing looks like...
<img src="http://pictureposter.audiworld.com/29770/trim_int.jpg">
Actually, once the retention system is undone, it will have to be put back together before you put the trim piece back on.
However, ALL YOU SEE FROM THE OUTSIDE IS THIS.
(This is just to the right of the grab bar screw hole. The trim is just barely pryed away from the car.) If you look closely between the GREEN wiring harness (left of the green harness) and the grey of the trim piece, you will see a tiny sliver of silver. That is the cable end you need.
<img src="http://pictureposter.audiworld.com/29770/cab_out_clos.jpg">
So, now that you can see the cable. You have to PULL ON IT until it POPS loose from the retainer clip. You will need to pull the cable about an 1" to 1-1/2"s. You should feel it POP or give.
Carefully, pry the rear retainer bracket from the middle of the B-Pillar, and now you can gently remove the A-Pillar trim. Pull up and out away from the windshield. Now it should look like this!
<img src="http://pictureposter.audiworld.com/29770/nak_pil.jpg">
With the trim piece removed, you need to remove clip that should STILL be in the metal pillar and reinstall it back in the trim piece. You will have to insert the head of clip in the trim hole, and slide the retention clip over the head. See the picture above!
Now go hardwire your V1 or Escort! Actually, both units use a 4-wire flatwire with a fone plug on the end. So, the same wiring harness could be used for EITHER.
With the trim clip reinstalled on the trim, installation is basically the reverse! Make sure that the trim piece is seated firmly and the clips are secure.
Don't forget to put the cloth tape back on the wires from the visor removal. Also, put the rubber seal back on the trim pieces like it was before. Use your fingers or something smooth to reseat the rubber piece over the A-pillar trim. NO screwdrivers. You might tear something!
Good luck! Remember this is just what I encountered with my '01 A6 2.7T. Your car may be slightly different. I take no responsibility if you try doing this and damage your car, yourself, your love life or anything else!
Old 07-14-2002, 08:28 AM
Junior Member
Jack Orr's Avatar
Really good pics, but my installation of an Escort looks great, and it took 20 minutes.
Old 07-14-2002, 08:31 AM
New Member
jimljewel's Avatar
Did you wire to the HomeLink lead?
Old 07-14-2002, 08:39 AM
New Member
jimljewel's Avatar
Default Found your old article how you wired. I mount my Escort right next to mirror.
I wanted the wiring under the headliner and down the A-pillar. This gives me good visibility to rear with the detector.
Old 07-14-2002, 09:58 AM
Elder Member
Bollinger's Avatar
Default that's great, put it in the tech section
The A6 tech section is so tiny. All you'd have to do is reformat your article a little and sent it to the owners and they'd put it up there for you.
That'd be great to see up there.
Old 07-14-2002, 11:35 AM
Stoney's Avatar
Default Valuable information, Thanks. But, I simply pushed the cable under the windshield edge...
... of the headliner, then the pillar liner. I fed the cable through the dash at that point where the pillar meets the dash, using a stiff wire taped to the cable, brining it out to the door opening near the fuse box.
This took some time (although less than removing the pillar liner), because I didn't want to damage the pillar liner. Also, it took some fishing around with a stiff wire to clear the catch points in the path between windshield and door behind the dash.
Also, I was unsure where the air curtain was positioned, so I was very gentle. Your pictures show that it is close to the door-edge of the pillar liner, so one is fairly safe pushing a cable in through the windshield-edge of the pillar liner. One should NOT use the door-edge of the pillar!
I can't recall exactly where I tapped into the switched 12v down by the fuse box, but I think I used the wire splicer that came with the Valentine One radar detector. I think I added an inline fuse holder, to be safe in case my cable was pinched and shorted at some point in time.
This seemed to be the easiest way to hard wire a V1, and looked perfect to my eye.
Old 07-14-2002, 11:42 AM
Stoney's Avatar
Default Can anyone help me find the message that showed how to wire to overhead lights?
I remember seeing either pictures or diagrams from the Bentley manual, or both.
Wiring here is nice because the detector goes on when you unlock, and thus goes through its noisy self-test before you get in! Also, it is the shortest path available.
Old 07-14-2002, 01:52 PM
Alf Arkin's Avatar
ditto
Old 07-14-2002, 05:17 PM
kjb99's Avatar
Thats what I was thinking!
Old 07-14-2002, 08:40 PM
New Member
Keith's Avatar
I just used a popcycle stick to push the wire behind the A pillar - took 5 minutes
Quick Reply: '01 A6 A-Pillar Removal (long) w/Pics
