02 A6 quattro 2.7
02 A6 quattro 2.7
I've looked through posts here and haven't found this info, so please forgive me if this is a common nerbie question. Looking at buying an 02 A6 Quattro 2.7 with the tiptronic automatic. The little bit of info I've found seems to indicate the sterring wheel should have some controlls on it, at least the two tiptronic buttons, if not all the radio buttons etc. But as you can see in the photo below, this car does not. Is this normal? Has the wheel been replaced with an incorrect wheel? What about the radio and other controls? Are they all optional, or should they also be standard?
This is a shot of the cockpit showing the steering wheel.
You might want to check out the steering wheel for an existing airbag and/or the car fax for collision repair…sometimes wrecks are repaired without replacing the expensive airbag…they use a cosmetic airbag cover without the airbag to save about $1100.
My 01 2.7 tip does not have any buttons on the steering wheel. Also have a 2000 2.7 that has the buttons. Never use them. Aside from Sloop's concerns ...
Thanks guys. The main reason I was asking was exactly the concerns sloop brought up. It raised a flag for me that they might have replaced parts because of an accident. We are doing a Carfax on the car to make sure it wasn't in a major accident. So next question is, if the car did come with that steering wheel originally, will the wiring for the buttons still be there? In other words can I buy a wheel with the buttons, and be able to hook everything up? In other brands wiring for features not used is in the harness, it's just not connected to anything. Does Audi also do this?
Gery
Audi allroad
03-12-2018 05:14 AM
Gery
Audi allroad
03-12-2018 02:31 AM
Gary @ Ronal
10-13-1999 10:53 AM
Gary @ Ronal
10-12-1999 11:05 AM
