Car just died at idle last night. 16 codes. Any ideas where to look for my electrical gremlin.
Old 04-05-2008, 05:28 AM
Paracaidista2.7T's Avatar
Default Car just died at idle last night. 16 codes. Any ideas where to look for my electrical gremlin.
16 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17880 - EVAP Leak Detection Pump: Short Circuit to Ground
P1472 - 35-00 - -
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
17938 - Camshshaft Timing Adjustment: Short to Ground
P1530 - 35-00 - -
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
17548 - Oxygen (Lambda) Sensor: B2 S2: Internal Resistance too High
P1140 - 35-00 - -
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating Circuit: B1 S1: Short to Ground
P1115 - 35-00 - -
17527 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1: Short to Ground
P1119 - 35-00 - -
TIA.
Old 04-05-2008, 05:59 AM
Tech Guru
4Driver4's Avatar
Clear codes. Attempt to restart. Check codes.
Old 04-05-2008, 06:19 AM
Default Cleared. Starts and runs, disco dash. Same codes. ABS and AT report no load signal.
I checked main harness from ECU to MAF, O2s, and other sensors. Nothing obvious.
Old 04-05-2008, 06:28 AM
Default complete list follows:
VAG-COM Version: Release 409.1-S
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 4B0 907 551 T
Component: 2.7l V6/5VT G09 0001
Coding: 06752
Shop #: WSC 09223
WAUED64BX1NXXXXXX AUZ7Z0A187XXXX
16 Faults Found:
P1425 - 35-00 - -
P1472 - 35-00 - -
P1435 - 35-00 - -
P1530 - 35-00 - -
P1421 - 35-00 - -
P1547 - 35-00 - -
P1289 - 35-00 - -
P1121 - 35-00 - -
P1117 - 35-00 - -
P1453 - 35-00 - -
P1457 - 35-00 - -
P0102 - 35-00 - -
P1115 - 35-00 - -
P1119 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-00 - -
Readiness: 0110 1101
Address 02: Auto Trans
Controller: 4B0 927 156 DJ
Component: AG5 01V 2.7l5VT USA 1717
Coding: 00032
Shop #: WSC 00000
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 06397
Shop #: WSC 02325
1 Fault Found:
P1857 - 35-00 - -
Address 08: Auto HVAC
Controller: 4B0 820 043 AG
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 4B0 907 487 D
Component: Lenkradelektronik D03
Coding: 00602
Shop #: WSC 65535
No fault code found.
Address 17: Instruments
Controller: 4B0 920 981 GX
Component: C5-KOMBIINSTR. VDO D17
Coding: 02264
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15981
Shop #: WSC 02325
1 Fault Found:
01562 - Right Rear Door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr
Controller: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00006
Shop #: WSC 02325
Address 56: Radio
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00017
Shop #: WSC 00003
1 Fault Found:
00855 - Connection to CD changer
49-00 - No Communications
End --------------------------------------------------------------------------------------------------
Old 04-05-2008, 08:24 AM
Default Fuse 34 was blown. Suspect a short somewhere near rear O2's, sound right? Anyone?
Can't get under the car to look as it is raining cats and dogs here. Hopefully it will clear up tomorrow.
Old 04-05-2008, 08:57 AM
johnkk's Avatar
Default Check battery compartment for water
A friend of mine had same symptoms with 2.7 t allroad and he discovered flooded area ahead of bulkhead. ECU was toast and blew some fuses.
Old 04-05-2008, 09:08 AM
Draining fine.
Old 04-05-2008, 01:46 PM
Follow up. B1 S2 shorted. Disconnected it until it dries out for a while and I can fix it.
Old 04-05-2008, 02:08 PM
Tech Guru
4Driver4's Avatar
Good find!
Old 04-05-2008, 02:20 PM
Default Seemed that rear O2s would be the place to start looking. Longer wires, higher potential for damage.
Now, I wish the rain would stop so I can fix it. I got rained on enough just trying to find it. I unplugged the sensor, changed the fuse, cleared the codes and waited to see what happened. I tried B2 S2 first, and pop went the fuse. Did the same for B1 S2 and found success.
Quick Reply: Car just died at idle last night. 16 codes. Any ideas where to look for my electrical gremlin.
