2000 4.2 Overheats, white smoke from exhaust
#11
Yes it did. I was aware of that. When I saw that the fans weren't working I thought it might be just that to fix. Get lucky, you know? But I knew it was overheating and I bought it with intentions of doing water pump thermostat timing belt. Just didn't think I'd have to replace head gaskets. In my research the past few days, it seems likely that the cam chain tensioners might need to be replaced. It all adds up to a pricey bunch of parts. I don't mind doing the work. But the time to do it all in scarce.
#12
Most likely the tensioner shoes.
Lots of labor involved…have fun with the head gaskets. 4.2 is a good car..if it weren't for those tensioner shoes and upcoming TB/WP service on our old 4.2 I probably would have kept it for a few more years for my daughter to run.
#14
I meant that it's unlikely the tensioners need to be replaced.
Most of the time it's just the plastic shoes. They're on ebay for like $20 a pair and you need two pair for the engine. I've not seen a dealer p/n for the 4.2…they come as an assembly with the tensioner.
#15
#16
Time to take account fore what you have.
1) How nice is the car in total?
2) How much will it cost to get it right?
3) How much is the car worth if sold?
4) Add #2 and #3 and think about what else you can get for that amount of money.
5) Make a decision!
5) Make a decision!
#17
Good points. I definitely inherited a problem.
I got the car at $1400. I'm not sure I could sell it to someone with the knowledge that the head gaskets aren't solid. That's kinda below my ethical standards. I think I'm going to go at it full bore. Maybe put 1000 or 1200 in parts into it. That brings it up to around the kbb value. At least that's how I'm justifying it to myself. also I think once it's all put together properly, it'll last a while.
#18
I would have a good Audi shop also look it over and make a list of everything it is going to need in the next year or so. You might have a few more $100 to $500 surprises you need to put in your budget.
Suspension arms, Transmission oil seals, Transmission fluid change, exhaust system parts, and such come to mind.
Maybe you got lucky and the last owner already did a lot before he gave up on it?
#19
Overheated engines have a legacy. I would suggest either accepting a mistake was made and junk it. Or, buy another and keep this one for parts.
#20
