2001 A6 Avant washer fluid leak
Old 08-01-2015, 05:57 AM
Jerry L's Avatar
Default 2001 A6 Avant washer fluid leak
Hello, noticed at work yesterday a puddle under the drivers side near front of body area out towards side of car
On investigation washer fluid dripping out of the spot welded support area that runs front to back near front where it gos up to start fire wall, there is a formed drain there it was dripping out of
Feeling around (what you can) the tank area I found nothing.
Any standard failures that may cause this?? Tank, hoses connectors pump (is working) to look at to start
Thanks for any tips in advance!
Regards
Old 08-01-2015, 08:35 AM
N_Jay's Avatar
I would guess that is the drain for the are where the battery and all are.
Pull off the cover and see if your washer hose is leaking into that area.
Old 08-02-2015, 02:44 PM
SloopJohnB@mac.com's Avatar
Default Pump grommet to tank have been known to fail.
Regards
Old 08-03-2015, 06:14 AM
Jerry L's Avatar
Thanks, will look at both this evening, I am more inclined to think pump to tank as it was a big puddle and I had not been using the washers
Thanks again to both of you, will report back!
regards
tcoble33
A7
10-10-2017 01:17 AM
crusininda944
Audi 100 / A6 (C4 Platform)
07-12-2007 12:39 PM
Skizsam
01-15-2004 04:46 AM
skategoat25
Audi allroad
04-25-2003 05:10 AM
kccmc
04-14-2003 03:02 PM
Quick Reply: 2001 A6 Avant washer fluid leak
